Old 05-17-2010, 07:00 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Polish or Seal Seams First?
Well I finally got a few days off and am ready to start the polishing of our 29" 1978 Ambassador. Should I seal any questionable seams first or polish and then seal. After spending yesterday polishing the two propane tanks...I am thinking I am in for a real job! Any advice would be helpful. Thanks!
TAC PA-5
Roadrunner is offline   Reply With Quote
Old 05-17-2010, 07:11 AM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I think fixing the seams first, that way when you polish and "smudges" of Vulkem would be removed.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 05-17-2010, 07:15 AM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I take the opposite approach.
I polish first so that you get a good clean surface all over, including at seams. It is hard to polish up to the sealant bead without damaging it.
After polishing, clean the seam area good with denatured alcohol or similar before sealing the seams.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-17-2010, 08:18 AM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Here's what we do and why...
"Seams first" - just our logic, but not everybody may agree. We remove out all the old, cruddy sealer with popsicle sticks & mineral spirits, then polish the seams, clean them really well - again with popsicle sticks & mineral spirits, then reseal them with fresh vulkem/parabond.
We've done this on both trailers and feel that it makes sense (at least to us) for a couple of reasons. If you leave the old sealer in place while polishing then reseal afterwards, the old sealer can chunk out and get imbedded in the buffs which causes undue scratching. By doing it this way, you can get the seams buffed up really well, then sealed which leaves the sealer cleaner in the end. If you seal first w/o polishing the seams - the polishing compound gets gooped up on the new sealer because we are trying to get the 55 years of oxidation off and working the area harder.
As we've worked on the trailer, we would take things off, then polish around the area before putting parts back on. This way, the hard work is done around all the details, seams, joints, drip caps, etc. and just the flat parts are left. Yes, we still will go over those areas again, but it's a touch-up, not the original cut, so the compounding isn't as big of a deal.
You do have a funny looking trailer for awhile using this method with the polished seams only, but it's definitely a conversation piece! Looks like orange segments ~
Shari
Old 07-08-2010, 06:09 PM   #5
1973 31' Sovereign
Waller , Texas
If I may threadjack a little- we have seams that need caulking, too. We plan to strip (with the peroxide based stripper) and polish, too. Do we need to strip before caulking the seams? Will the stripper fubar the caulk?
Thanks!
farmette is offline   Reply With Quote
Old 07-09-2010, 08:46 AM   #6
InsideOut's Avatar
1956 22' Safari
Images: 108
Definitely strip before doing any new caulking. You don't want clearcoat under the new caulking...if there is, then you strip it will compromise the caulk.
Shari
Old 07-09-2010, 10:24 AM   #7
1964 26' Overlander
Bentonville , Arkansas
Very good question - if I have it right.
1. Wash the AS
2. Strip the clear coat
3. Polish the seams
4. Clean the seams
5. Apply Vulkem
6. Finish polishing the enitre AS
7. Wax
When do I get to drink a pop with foam on top and enjoy the sunset?
Ginder75 is offline   Reply With Quote
Old 07-09-2010, 10:54 AM   #8
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Step 1a, step 2a, step 3a, etc. etc.
Old 07-09-2010, 11:32 AM   #9
InsideOut's Avatar
1956 22' Safari
Images: 108
TeeHeeHee!
Next October!
Shari
How to seal window joints & seams prior to painting? nick6930 All Argosy Trailers 10 03-17-2009 04:18 PM
Seal seams, then polish? (59 18'er) Jephellis Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 07-29-2008 03:46 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
Parbond or Gutter Seal for Exterior Seams??? mwmoss Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 02-23-2005 08:36 AM
