Old 02-05-2014, 10:38 PM   #1
huntingdon , Pennsylvania
polish and seal or seal and polish
should i seal all the leaks / seams first then polish or should i polish and then seal leaks and seams?
thanks for the info .. not sure what i should do first
kokomoscalls is offline   Reply With Quote
Old 02-06-2014, 07:13 PM   #2
Mixter's Avatar
1976 27' Overlander
I'm in the same boat. I'm polishing, then sealing. Which is frustrating because I'm trying to keep the water out! But I want to put a fresh bead of sealant "AFTER" I polish.
I suppose it depends on what you're doing. I am in the middle of a shell of resto. So as I pull out a roof vent, for instance, I will polish around the opening, then seal in the new vent.
One note that may help you is... the only places that I have found need polishing before sealing is around the window tops, and the vertical seams. If you clean & polish those areas first, then seal them, then you can polish the rest later.
Hope that helps!
Mic
Mixter is offline   Reply With Quote
1968 Avion C11 Truck Camper restoration jforb Vintage Kin 310 01-04-2016 06:20 AM
Tail light from bezel removal Flying Cloud 23FB 2011 Papou General Repair Forum 7 06-17-2013 07:28 PM
Seal or Polish first JIMandPJ Ribs, Skins & Rivets 4 03-14-2011 11:58 PM
