Old 10-26-2011, 05:55 PM   #15
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Originally Posted by Splitrock View Post
Anybody do the 400 and 600 grit sanding?
Yep had to do that on the endcaps as they were seriously corroded
Took a looooong time to polish out where I had sanded
but It was much faster than trying to polish out the corrosion.
Used a dewalt random orbital sander and hook and loop sanding discs
ID:	143723   Click image for larger version
Darkspeed is offline   Reply With Quote
Old 10-26-2011, 06:11 PM   #16
Splitrock's Avatar
Sioux Falls , South Dakota
I see you bought three 3# bars of black and white compound. Did you use them all up?
Thanks for the answer on the sanding!
Old 10-26-2011, 06:20 PM   #17
Darkspeed's Avatar
1972 31' Sovereign
I used all the black, infact if you have a really bad spot if you touch the black bar to the back side of the wheel as it is spinning it will work through the scratch really quickly.
The white I had a little left but Im sure I will use it doing touchups.
I have an unopened NuviteS for when everything is done Im going to try out.
I did not post it but I had to reorder a 10" airway wheel as I wore the others down to the cardboard center hub.
Old 10-26-2011, 06:27 PM   #18
Darkspeed's Avatar
1972 31' Sovereign
Do yourself a favor and buy a few of these at Lowes and use a fresh one everyday
Old 10-26-2011, 06:43 PM   #19
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
FYI.... I strongly suggest that you do not sand your Alclad Aluminum Skin before polishing!!! However if you must I would start with 500 grit...750 grit... 1000 grit and then 1500 grit. It you uses dark grey bar you can skip the 1500 grit if you start with red bar then uses the 1500 grit. I find that the 1500 grit with red bar gets the best result! I find that the grey bar tends to leave strange groves that will not get taken out!
If you can get away with 750 grit to start with then go that way rather than 500 grit!
I am also finding that green bar seams to work on brand new Alclad the red bar seams to be too aggressive and I am getting a better result with the green.
One last note that seams to always be missing from polishing post is to clean...clean...clean... between each step! The cleaner you can get the aluminum (get the black off) the better the end result is!
Hope that helps... Good luck... and happy shinning!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 10-26-2011, 06:46 PM   #20
Splitrock's Avatar
What the . . . ? Did you hold the bar in your teeth? You held that 3,000 rpm polisher with a 10" wheel with one hand, balanced on a rib, and fed it stick on the fly? Holy cow!
I'm impressed!
Old 10-26-2011, 06:58 PM   #21
vinstream's Avatar
I forgot to mention! When sanding I use a spray bottle with 1/8 dish soap & believe it or not crushed ice! It sands faster smoother and your pads last three time longer...
www.VINSTREAM.com
WBCCI # 1962
Old 10-26-2011, 07:06 PM   #22
Darkspeed's Avatar
1972 31' Sovereign
I'm impressed!
After the first 40hrs you reach Jedi Master and you end up with the handel in one hand and the cord end or the polisher resting on your mid section giving you a free hand to feed the bar with the other..
Besides when the wheel is up to speed it feels really stable.
you want to be standing with the polisher at waist level without putting any real pressure on it. Never had it kick except when I got too close to an open window frame and it grabbed the edge of the frame.
Old 10-26-2011, 07:16 PM   #23
Darkspeed's Avatar
1972 31' Sovereign
This is my typical polishing stance / grip
ID:	143729   Click image for larger version
Old 10-26-2011, 07:53 PM   #24
Splitrock's Avatar
Oh wow! Now I'm more impressed!
Thanks for your posts. VERY helpful to me.
Old 10-26-2011, 08:08 PM   #25
Darkspeed's Avatar
1972 31' Sovereign
Cool.. No problem..
You need to start by polishing the word " Lazy A$$ " on your dull airstream door.. and then vow not to polish out the door until last... Its a great motivator...
Actually it is super addictive because you see results instantaneously.. very rewarding..
Old 10-26-2011, 08:16 PM   #26
Splitrock's Avatar
You need to start by polishing the word " Lazy A$$ " on your dull airstream door.. and then vow not to polish out the door until last... Its a great motivator... ..
Ha! I'll remember that. I won't start till spring. Winter starts here next week.
Old 10-27-2011, 07:14 AM   #27
ELKAY12
1974 25' Tradewind
1993 25' Excella
Rocky Mount , North Carolina
thanks so much for all the post / getting stuff together to start job maybe 1-2012
elkay12 is offline   Reply With Quote
How do you polish the aluminum bumper ElliotA Bumpers & Bumper Storage 14 08-28-2013 09:38 AM
Strip & Polish 89 Excella 32' cjack99 Cleaning, Stripping & Polishing 14 04-06-2012 10:03 AM
Newbie needs to strip & polish billy1davis Cleaning, Stripping & Polishing 1 10-22-2011 09:08 PM
Polish a 1984? casa3805 Clearcoat, Exterior Paint & Trim 11 06-26-2011 09:13 AM
Seal or Polish first JIMandPJ Ribs, Skins & Rivets 4 03-14-2011 11:58 PM
