Old 03-29-2010, 04:58 PM   #1
76 Argosy 28' MH
john roeder's Avatar
1975 28' Argosy 28
Springfield , Ohio
plex glass
Hi all. Argosy 28' 1976 has the drivers and passer side front windows which are plex glass. just wondering if there is something out there to bring em back to life with out replacing. Few straches and dull.
Thanks John
Chief 1, You light em = we fight em
john roeder is offline   Reply With Quote
Old 03-29-2010, 05:07 PM   #2
69 Silverback's Avatar
1969 27' Overlander
Firth , Nebraska
Yes there is, we do it to windows the on aircraft . I'm not involved in that part of our work. I do know that it is labor intensive and time consuming.
I will ask at work and see if I can get some more info on it.
Loren
69 Silverback is offline   Reply With Quote
Old 03-29-2010, 05:10 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I've used 600 and 800 wet sand paper, followed by Fine Nuvite and have gotten perfect plexiglass as a result. Be careful if you use a buffer with the Nuvite. If you overheat the plastic, it's a goner.
Zep
Old 03-29-2010, 05:15 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
There is a product that I have used to remove some scratched from my acrylic aquarium. It is called Novus Plastic Polish, made by Nivus, Inc. of Minneapolis, Minnesota. It is a three step process that starts of with a heavy grit liquid polish, then you move on to a lesser grit liquid polish, finally to a non grit finish liquid polish.
It's quite a bit of work and elbow grease to get out the scratches, but it does an excellent job. I don't know how it would do on the haze.
It has been over ten years since I bought the Novus polish. I don't recall where I got it. I don't even know if the company is still in business.
Brian
SuEllyn & Brian McCabe
Old 03-29-2010, 05:18 PM   #5
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Thanks John
MICRO-MESH from Aircraft Spruce
Michelle TAC MT-0
Sarah, Snowball
Old 03-29-2010, 05:37 PM   #6
76 Argosy 28' MH
1975 28' Argosy 28
Springfield , Ohio
thanks loren. and thanks to all. just hate to leave it that way because the rest looks great.
Thanks again John
Old 04-03-2010, 03:54 PM   #7
1969 27' Overlander
Firth , Nebraska
John,
Sorry about the delay. We use 3M Finessite [spelling]. For mild scratches, it is sanded out to 3000 grit . Then start with the coarsest of the three grit and working to the finest.
The 3M product is spendy and available at autobody supply houses.
Another product you may consider would be the kits that are for polishing plastic auto headlights. Should be able to find it at an auto parts place. One of the people I work with,has used it and said the results were good.
Good luck and I hope they turn out for you,
Loren
Old 04-03-2010, 05:03 PM   #8
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
I have used the liquids that are for polishing plastic auto headlights with some success on auto headlights. When we purchased our 1977 AS the smoked acrylic front window guard on the front was dull and somewhat scratched. On someone's recommendation I tried "Pledge" furniture polish - it worked great!
Worth trying?
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 04-03-2010, 05:22 PM   #9
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I worked for a large subway system and they threw pallets full of nice Lexan in the dumpster that had been condemned where the mar-guard coating had failed from the monster car-wash spinning brushes we used on the cars.
To get passable optical quality (after retrieving it from the dumpster and dragging it home) I found soaking it with RainX automotive windshield treatment two or three times sealed the pores and added a glazed finish, not perfect like new but 85% like new even on very worn Lexan. The treatment has to be reapplied but its $5 a bottle and near zero work!
Old 04-03-2010, 05:56 PM   #10
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
Hey John, try a can of Plexus. I have used it on motorcycle windshields that were oxidised to the point of being opaque. Most motorcycle shops carry it. Once you try it you'll never be without it. LJH
LJH is offline   Reply With Quote
Old 04-07-2010, 07:00 PM   #11
76 Argosy 28' MH
1975 28' Argosy 28
Springfield , Ohio
thanks to all but tradewind wins."Pledge" furniture polish really worked. looks new execpt for a few small sracthes, it really took the dullness out.
again thanks to all.
john
Want 66-67-68 glass? Inland RV Center, In Commercial Listings 0 02-05-2009 01:30 PM
66-67-68 tempered glass. Inland RV Center, In Commercial Listings 8 10-20-2006 01:24 PM
New glass William8979 Windows & Screens 3 05-11-2005 08:05 AM
Help, I need Glass for MH RichardT Airstream Motorhome Forums 0 03-21-2004 01:25 PM
Glass Wax InsideOut Cleaning, Stripping & Polishing 21 09-01-2003 02:31 PM
