Old 04-20-2010, 05:46 PM   #1
1976 31' Sovereign
Hiawassee , Georgia
Plasticoat Stripping
How many gallons of Removall 220 is required to strip a 31' Airstream???
john1dup is offline   Reply With Quote
Old 04-20-2010, 06:48 PM   #2
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern , Minnesota
Most likely you can do it with 2 gallons (or less). I stripped my '66 Safari which is 22' and used just about 1 gallon.
I advise using a pressure washer to remove the stripper but make sure the pressure is not too high. Start low and work your way up.
life is too short to drink cheap beer...unless that's all we've got and then pass me a cold one!
Steve "Dancin" Hansen
TAC MN-31
visit my almost yearly blog http://www.bluessafari.blogspot.com
GR8DANE is offline   Reply With Quote
Old 04-20-2010, 07:21 PM   #3
2001 30' Classic S/O
2001 36' Land Yacht XC Diesel 300 hp w/slide
Helotes , Texas
I used less than 1 gallon to strip my 28' from the beltline up, applying a second application in some areas
Ditto the power washer makes the job and removall work better
lsmith is offline   Reply With Quote
Old 04-21-2010, 07:21 AM   #4
1976 31' Sovereign
Hiawassee , Georgia
Thank You !!!
John
Old 04-21-2010, 08:16 AM   #5
jasper2222's Avatar
1996 25' Excella
Tallahassee , Florida
Where to buy
If the Removall 220 is the way to go where do you recommend finding. I have not looked anywhere as of yet. I have ends of trailer and one upper side that could use stripping. 96 25ft excella.
thanks,
richard
jasper2222 is offline   Reply With Quote
Old 04-21-2010, 08:31 AM   #6
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Vintage Trailer Supply used to have it. From what I understand, the company has been relocated out of the US but plans are being made to import the product stateside. You might contact Steve at vintagetrailersupply.com and get the scoop. Good luck and happy stripping!
TAC MN-31
Old 05-07-2010, 11:38 AM   #7
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
vintagetrailersupply.com has Removall 220 back in stock!!! happy stripping to all and to all a good night!
TAC MN-31
Old 05-07-2010, 12:15 PM   #8
1976 25' Tradewind
Erie , Pennsylvania
Two gallons is plenty if you apply right the first time. Make sure the weather is nice!!!! If you apply this stuff at temps under 50 you will need to do it again. Or at least I did. Make sure and apply with brush!!! Also I bought that as seen on tv hose attachment that blasts water at a higher PSI. Thing costed like $15 bucks at Walgreens. Anyway It took it all off like removing soap. Have fun!!!!
rollingbubel is offline   Reply With Quote
clearcoat or plasticoat Beverly II Clearcoat, Exterior Paint & Trim 2 06-09-2008 01:23 PM
Striping Plasticoat??? DKinsey Cleaning, Stripping & Polishing 4 05-18-2006 08:22 PM
plasticoat reynolds431 Clearcoat, Exterior Paint & Trim 1 10-06-2005 07:48 PM
So, what if I don't need to strip the Plasticoat? balrgn Cleaning, Stripping & Polishing 2 02-18-2005 03:41 PM
Plasticoat danesh Clearcoat, Exterior Paint & Trim 1 11-18-2003 01:47 PM
