Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 05-18-2005, 01:29 AM   #1
Bambi's Dad
Bambi's Dad's Avatar
Profile:  2006 19' Safari
Agua Dulce , California
Pits in my polish! Oh my!!!
Is it standard to have some pits, etc. that just won't come out in the polishing phase? Am I being lazy? Could I damage the aluminum if I get too carried away trying to get far enough down to remove it?
I'm just wondering of there is really a perfect polish job.
Bambi's Dad is offline   Reply With Quote
Old 05-18-2005, 02:16 AM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Question It's the pits alright!
We too had pits, especially in the front where pebbles get kicked up from the TV.
We minimized them by LIGHT wet sanding with 1000 grit wet or dry followed by 2000 grit...it basically took the rough edges off and smoothed the pits out so the polish didn't build up in the craters.
There's more detail in the polishing section on our website ~
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Last edited by InsideOut; 05-19-2005 at 10:44 PM. Reason: correction is in italics...Mr.InsideOut corrected my recollection
Old 05-18-2005, 07:06 AM   #3
TravelCloud
Profile:
In watching the airport guys, they advised against using a sanding block due to the shape of the trailer- they held it in their hands and it was folded in quarters so the sanding sides never touched each other, and was unfolded and re-folded as they wore down. The pitted areas that I saw them work on were sanded with 800, then 1200, then 1500, then polished out. Other areas they used the 1200 and 1500 only...
TravelCloud is offline   Reply With Quote
Old 05-18-2005, 09:30 AM   #4
Bambi's Dad
InsideOut,
Been to your website. Very, very cool. How did you do around the windows and all the nooks and crannies?
Old 05-18-2005, 09:48 AM   #5
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
I used both a buffing wheel on a drill and my Foredom Flex-Shaft tool. I didn't go out & buy the Foredom for this purpose, I had it already for use in my jewelry making hobby/business. It's much the same as a Dremmel, just more HP.
Shari
Old 05-18-2005, 09:53 AM   #6
Bambi's Dad
Thanks for that! I'm looking at a second Dremel type tool today. I have to do something as I can't get it right by hand. Just doesn't kick like the other areas.
Shari
Old 05-18-2005, 07:49 PM   #7
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Originally Posted by Bambi's Dad
InsideOut,
You mean ya gotta get the tight spots too! ALmost there, Still playin with the finish and wondering about wax...........
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
meguiars polish david h Cleaning, Stripping & Polishing 3 01-11-2003 01:42 PM
Help for new member... Cheryl 1978- 1979 Excella 500 23 12-31-2002 09:40 AM
polish a brushed trailer? john hd Cleaning, Stripping & Polishing 6 08-25-2002 11:03 PM
Best Polish to restore Airstream ?? bgow 1969 Overlander 1 08-06-2002 11:23 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 08:15 AM
