Old 07-25-2009, 07:30 PM   #1
2016 30' Classic
2009 25' FB Flying Cloud
Dade City , Florida
Pine Resin
Can anyone suggest a solution to removing pine resin from the top of our Airstream? We have tried a number of solvents with no success.
Thanks, Dave
dbaur is offline   Reply With Quote
Old 07-25-2009, 07:35 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Have you tried that bug off stuff you get at auto part stores.. It took the pitch off one of our cars...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-25-2009, 07:45 PM   #3
Mr. Decent's Avatar
1960 18' Traveler
Nomadic , Symmetry
Images: 21
Simple Isopropyl Alcohol works very nicely! I have used it on my 1960 to great effect for the removal of pines resin as well as have read that many use it on painted vehicle surfaces.
Mr. Decent is offline   Reply With Quote
Old 07-25-2009, 08:15 PM   #4
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
Also Acetone or Mineral Spirits should do the trick?
FLYNCLD is offline   Reply With Quote
Old 07-25-2009, 08:59 PM   #5
1976 31' Excella 500
New Castle , Indiana
You can go to your nearest Honda motorcycle dealer and buy a can of spray cleaner called Pro Honda. The stuff works amazingly well on removing tar so it might work on pine sap. For all the Harley riders you can also buy the same stuff, different name, at your local Harley dealer, but it costs twice as much.
TravisA is offline   Reply With Quote
Old 07-25-2009, 09:13 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Any ofd those things may work and I've used most of them, but that stuff can be real stubborn, and I use a tool I always have with me to help. It's called a fingernail.
WD-40 will take off duct tape glue and someday I'll have to try it on sap.
Gene
Old 07-25-2009, 09:37 PM   #7
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
We parked under a pine tree once....grrrr. Sap all over the truck and the trailer. Took the pine sap off with mineral spirits, it worked like a charm.
Speaking of duct tape.......someone mounted a picture to a friend's restaurant wall with duct tape. Would not come off without damaging the wall. A quick-thinking chef grabbed his little torch that he uses to carmelize desserts and heated up the tape. Came right off without a mark.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
http://chaosinature.blogspot.com/
Isadora is offline   Reply With Quote
Old 07-26-2009, 12:25 AM   #8
Mexray's Avatar
1978 28' Ambassador
Morada , California
Yes, WD-40 works great on pine sap - just used it yesterday...I sprayed a bit of the 'juice' onto a paper towel and it rubbed right off!
Ray & Pat; Morada, CA
Old 07-26-2009, 06:48 AM   #9
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Make sure it is a high percent type of alcohol. I use it to remove glue and it will work just remember to get a high percent usually found at walgreens.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 07-26-2009, 06:50 AM   #10
1970 27' Overlander
Did you know that 'many parts of a pine tree ARE edible!
Old 07-26-2009, 06:53 AM   #11
1970 27' Overlander
Gene
Yeah but fingernails can leave those little 'swirl marks'!
Old 07-26-2009, 09:04 AM   #12
Kevin245's Avatar
We use to use rubbing alcohol on our old classic cars. It dissolved the hard stuff very well.
Kevin
Eleanor Roosevelt
Old 07-26-2009, 09:26 AM   #13
FLYNCLD's Avatar
Bend , Oregon
Yes, alcohol does work pretty well. I just grab a beer and tell my wife "there's some pine sap on the AS"! Problem solved!
Old 07-26-2009, 09:49 AM   #14
Kevin245's Avatar
Whew....Was worried there...for a minute I thought you were using the beer to remove the sap. Around here we'd consider that alcohol abuse.
Eleanor Roosevelt
OK to use 3/4 Rustic Pine Boards? IronGiant Floor Finishes 2 05-10-2009 08:09 AM
Pine Sap Removal dwsafari Cleaning, Stripping & Polishing 15 04-10-2009 11:41 AM
Plastic resin Code '1' PET tank repair fotochop Waste Systems, Tanks & Totes 11 01-28-2008 08:50 PM
Fiberglass Resin to coat the new floor? JeepinAudiophile Repairing/Replacing Floor &/or Frame 11 11-08-2004 07:21 PM
Floor repair:epoxy vs resin TomW Repairing/Replacing Floor &/or Frame 11 12-24-2003 12:32 PM
