Old 07-26-2009, 09:13 AM   #15
Mexray's Avatar
1978 28' Ambassador
Morada , California
If alcohol does indeed work, I guess I could allocate a few drops of my 151 Ron Rico from the liquor cabinet, in a pinch - just don't use it around any open flame...
Ray & Pat; Morada, CA
Old 07-26-2009, 10:32 AM   #16
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by FLYNCLD View Post
Also Acetone or Mineral Spirits should do the trick?
I don't know this for a fact, but I would have thought that acetone would be a pretty "hot" solvent somewhat akin to lacquer thinner and might have the ability to remove clear coat if applied. No? Mineral spirits I would think should be safer.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-26-2009, 12:23 PM   #17
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
No clear coat on our AS, so don't know the answer....you could be right. Mineral Spirits works quite well, although not as fast.
I think 151 might actually remove the aluminum!!
As for the beer, it should be applied liberally!
FLYNCLD is offline   Reply With Quote
Old 07-26-2009, 12:34 PM   #18
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I store my trailer under a pine tree (for lack of a better spot). I've found that simple HOT water on a rag melts it right off. Haven't had to go to other extremes yet.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-26-2009, 12:40 PM   #19
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
In the intense sun of the high altitude desert of the Southwest, pine sap gets very, very hard and is difficult to remove after it bakes for a while. I know I should remove it quickly, as soon as I get around to getting out the 8' ladder, finding something to remove it with, etc., etc. I have ordered a phaser as that will be more effective and I won't need a ladder-just set it to high stun.
Gene
Old 07-27-2009, 07:29 AM   #20
2016 30' Classic
2009 25' FB Flying Cloud
Dade City , Florida
Isopropyl Alcohol is the clear winner with Maine pine resin. Works like a charm. Thanks to all of you for your suggestions.
dbaur is offline   Reply With Quote
OK to use 3/4 Rustic Pine Boards? IronGiant Floor Finishes 2 05-10-2009 07:09 AM
Pine Sap Removal dwsafari Cleaning, Stripping & Polishing 15 04-10-2009 10:41 AM
Plastic resin Code '1' PET tank repair fotochop Waste Systems, Tanks & Totes 11 01-28-2008 07:50 PM
Fiberglass Resin to coat the new floor? JeepinAudiophile Repairing/Replacing Floor &/or Frame 11 11-08-2004 06:21 PM
Floor repair:epoxy vs resin TomW Repairing/Replacing Floor &/or Frame 11 12-24-2003 11:32 AM
