Old 04-06-2014, 05:48 PM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Paste vs Bars?
Hi,
The last two years I've polished our 1959 Tradewind with Nuvite, buffing wheels and cotton pads.
I see some folks using the 8" buffing wheels and hard polish bars that come in green, red, and white colors.
Are the bars better than nuvite?
Can anyone recommend a brand or good place to buy bar polish online? I'd like to give it a shot.
Steve
steveirving is offline   Reply With Quote
Old 04-06-2014, 05:52 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Caswell and Jetsco....two companies with excellent products. Search here ...those names /....you will find more information and comments.
Old 04-06-2014, 06:52 PM   #3
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I started with Nuvite and switched to the Jestco products. The Jestco process was much faster for me and I think I was getting better results. I'm sure others will have different opinions, but I'm now a bar guy.
Jestco Products Buffing Supply (Powered by CubeCart)
Thalweg is offline   Reply With Quote
Old 04-06-2014, 06:58 PM   #4
DFlores's Avatar
1968 22' Safari
Bars here,with treated wheels
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 04-09-2014, 04:29 PM   #5
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
I use both. Bar and edge wheel works very well on and around window, door hatch frames, seams, ect. Pads and paste on the flats. Both work very well on a dewalt angle polisher. On the old rigs I do pitting is usually evident. The edge wheel with red bar does a pretty good job of smoothing these areas out. When using the edge wheel with coarse grit be careful of heat, use light pressure and low RPM. I use www.buschshineproducts.com. They have tools and compounds for anything you encounter and decent prices.
putback is offline   Reply With Quote
70s Wallpaper Paste BrockLives Upholstery, Blinds, Walls & Interior Finishes 1 08-28-2009 08:15 AM
Weight Distribution Bars-Avoiding a mess JaceBeck Hitches, Couplers & Balls 18 11-25-2004 12:29 PM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
Equalizer bars...need one. boltos Hitches, Couplers & Balls 3 09-26-2003 09:21 AM
photo paste try Ladi Holovsky All Argosy Trailers 2 08-11-2003 10:23 AM
