Old 03-23-2010, 10:59 PM   #1
Shan & Ellen
Shan's Avatar
1954 15' Byam Holiday
1962 22' Flying Cloud
Santa Ynez , California
Unhappy Oxidized and pitted skin
Hi all:
We have a 1955 Flying Cloud that I'm polishing. The problem I'm having is the skin has heavy oxidization and pitting in a lot of areas. I'm finding it's taking a lot of time polishing the spots out. Does anyone have any ideas or magic solutions other than replacing the skin? I'm hoping for a magic formula that wipes on wipes off. (I'm dreaming)
Any help would be great. Thank you
Shan
Shan & Ellen
Shan is offline   Reply With Quote
Old 03-23-2010, 11:28 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Have you checked out the polishing forum? There are lots of great methods, tips & tricks...unfortunately, none of them are quite as simple as "wipe on, wipe off".
We used the Perfect Polish (Nuvite) compounder method on our first trailer, our '64 GlobeTrotter (my avatar). We're using the rouge bar method with our second trailer, our '56 Safari. Both are finished up with the Cyclo Polisher & "Nuvite S".
Shari
Old 03-24-2010, 06:57 PM   #3
Shan & Ellen
Shan's Avatar
Thank you Shari, I will look into it
Shan & Ellen
Old 03-28-2010, 02:37 PM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Originally Posted by Shan View Post
Hi all:
Shan
I am having the same problem.Mostly corrosion around the rub rails and where the emblems are mounted.I am using the bar method.After 6 passes it removes most but still alot there.I hate to wet sand.and suggestions?
bwaysteve is offline   Reply With Quote
Old 03-30-2010, 12:40 PM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
We had to lightly wet-sand the front panel on our '64 because it had pretty severe road rash pits...you can see pics here. We didn't have the crusty/flakey white kind of corrosion though, just pits with raised edges like moon craters. So far we haven't had to do that on our '56 - it's in better shape in that regard.
The white crusty corrosion is more like a cancer...it eats out the skin. Pretty hard to polish through that.
Shari
Old 04-02-2010, 01:04 AM   #6
Shan & Ellen
Shan's Avatar
Thanks Shari
I will try wet sand and see how it works out.
Shan
Shan & Ellen
Old 04-02-2010, 07:22 AM   #7
InsideOut's Avatar
1956 22' Safari
Images: 108
I'm anxious to see how it works out for you...just do as little as possible to achieve the results - don't over do it or you'll go through the Alclad layer and have bigger issues to deal with. We used 3M Ultra Fine 1000 grit color sand paper and literally just lightly took the edges off the pits. Keep in mind the sand paper causes scratches that later have to be remove so the fewer & lighter the better! We only did it as a last resort - fortunately the results were exactly what we needed. Good luck!
Shari
Old 04-03-2010, 03:28 PM   #8
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Emblems
Today I removed my AIRSTREAM emblem on front of the 65.It has a thin metal frame around it.It was the worst of the corrosion( maybe another 10yrs. a hole)Wondering if after I clean up and remount the emblem I was thinking about using Vulkem with the new rivets(a given).Should I also do the top and sides underneath with butyl tape and leave the bottom open as you would do a marker light to let out moisture?
Old 04-03-2010, 04:56 PM   #9
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Hi all:
Shan
You are not going to find a wipe on wipe off product in this life time. However you can cut to the chase with a product called 'Gravel in a Bottle' made by 3m company...google it. It is a no nonsense liquid compound creme that stays wet long enough to knock out the crud and oxidation. It is around fourteen dollars for a LARGE bottle (your going to love that) just remember to remove all the black afterwords before going on to polish with something like mothers aluminum polish. Continue on with your mission and don't give up EVER! Bill PS Alclad too and have not yet even begun to go thru it...it's thicker than you think for that year model.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 04-03-2010, 07:31 PM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Just finished a polishing session on our Caravel. When I first polished it, a number of years ago, I went absolutely nuts, making sure that every little corner, every little pit, every spot was perfect.
Guess what? This is not a Bugatti Royale headed to Pebble Beach. It's an old Airstream with pits, dings, scrapes and assorted blemishes. This time it will look very nice, but perhaps not perfect.
It's a travel trailer folks. Don't make yourselves crazy trying to make it "Street Rod Perfect". It's not going to happen. Use it and enjoy!
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-03-2010, 07:51 PM   #11
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Today
Just into my fourth day of my 1st cut with gray bar.It occurred to me to look at those 50 yr. old dings as beauty marks.Thanks for the reminder!
Old 04-09-2010, 05:57 AM   #12
1970 27' Overlander
Gravel in a Bottle by 3M
Hi all:
Any help would be great. Thank you .
Shan
Here's a picture of that 3M product--you can order online
Pitted Alcoa wheels SeanWilmNC Land Yacht/Legacy Motorhomes 13 07-06-2017 03:57 PM
Discolored/oxidized exterior coverings jsprad Cleaning, Stripping & Polishing 0 10-02-2007 12:30 PM
Oxidized latch / handle assemblies osp6179 Doors & Locks 1 09-04-2005 10:32 AM
Pitted Caliper Pistons Buttercup Brakes & Brake Controllers 2 07-17-2005 06:34 AM
Oxidized Aluminum exterior Airstreammam Cleaning, Stripping & Polishing 1 08-26-2004 07:45 AM
