Old 10-13-2019, 04:27 PM   #1
Mucky
muck's Avatar
1973 25' Tradewind
MALVERN , PA
Oxidation? Filaform?
Hi Everyone - we stripped the clearcoat on our '73 this weekend and are left with some ugliness. See pic. Is this oxidaton or filaform or something else? It's only on the street side and top so I assume it was caused by baking in the sun. Why is it not on the back panels? Thanks in advance for your help! Brian
muck is offline   Reply With Quote
Old 10-13-2019, 05:10 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The end caps are a different alloy, 6061 I think, and has better corrosion resistance then the 2024 alloy of the center panels.
Old 11-15-2019, 04:13 PM   #3
1998 19' Bambi
Woodville , Texas
The end caps might have been replaced with newer and possibly Alcoa clear coated replacement panels. The lower and center rear end caps on my 1998 Bambi were replaced but until I stripped the clear coat and the Olympic rivets oxidized some they looked like bucked rivets.
Woodbilly is offline   Reply With Quote
Old 11-15-2019, 04:40 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Looks like it might be residual clear coat. What are you using for stripper? Filiform corrosion looks like ice crystals and is usually localized I think. Was it there before you stripped? A close up photo would help.
Linex over Filaform Corrosion Mukfolks Exterior Restoration Forum 0 07-27-2015 02:24 AM
Yes, another Filaform thread AWCHIEF Ribs, Skins & Rivets 19 08-18-2014 11:25 PM
Does oxidation cause oxidation bmklawt Ribs, Skins & Rivets 9 02-09-2009 10:21 AM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 06:49 AM
Ouestions 2-oxidation&clear coat Sharon Lee Cleaning, Stripping & Polishing 0 07-01-2002 09:20 AM
