Old 09-09-2016, 04:59 PM   #1
1954 25' Cruiser
Cody , Wyoming
Oxidation
Is there another option to get rid of oxidation other than polishing?
jtfink is offline   Reply With Quote
Old 09-09-2016, 05:17 PM   #2
1976 31' Sovereign
Oswego , Illinois
There are some washes for aluminum that removes some lite corrosion but leaves aluminum white ish. it is basic acid content. I have used on wheels but never on AS. Bill
Old 09-09-2016, 05:20 PM   #3
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Acid wash like Alumi bright is a acid wash, it leaves to aluminum a satin finish. You also have to strip the clear coat first. Many folks on this forum worry that the acid wash can eat away at the seals.
Silverflames is offline   Reply With Quote
Old 09-09-2016, 06:03 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
We just let our 63 Safari 'Patina' naturally, the most we did was remove some corrosion spots with scotch-pads.
Name:	STREAM'N IN NEW ENGLAND.jpg
PFC
but Iím the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-09-2016, 06:17 PM   #5
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
Depends on the year of AS (coated vs not) and how heavy the corrosion is.
Our Pacer spent 57 years in Wisconsin. We bought it from the original owner in 2013, the front was pointed toward the road much of it's life. I'm guessing the road salt was plowed to the sidewalks and then snow blown on the AS.
This after two heavy cuts with a tripoli solution. The pitting will never go away.
I have done another heavy cut and it is slowly improving.
The Dog House - http://www.airforums.com/forums/f104...er-111301.html
Toddzilla is offline   Reply With Quote
Does oxidation cause oxidation bmklawt Ribs, Skins & Rivets 9 02-09-2009 10:21 AM
Oxidation davthr Cleaning, Stripping & Polishing 0 02-09-2003 09:06 AM
oxidation don m Cleaning, Stripping & Polishing 4 09-25-2002 06:17 PM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 06:49 AM
Ouestions 2-oxidation&clear coat Sharon Lee Cleaning, Stripping & Polishing 0 07-01-2002 09:20 AM
