Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 07-01-2002, 09:20 AM   #1
Sharon Lee
Sharon Lee's Avatar
Profile:
Ouestions 2-oxidation&clear coat
I just remembered another question.
The previous owner took scotchbrite to a portion of the top of the trailer
(someone should hang him for it) It's a spot about 1 foot long and a half a foot wide. How could I get rid of it? Do I need to guess what grit he used and work up from there? What grit is the finish? I also noticed a good amount of oxidation near the roof. Would regular lacquer thinner work to remove the coating? It's a plastic coat isn't it? What is the replacement for the clear coat that you recommend? Is it something that comes in a spray can or could you use a spray gun to apply?
Once you have it removed what do you recommend to polish it?
And what happens if you just leave the oxidized spots alone??
Thanks again- Sharon Lee
Sharon Lee is offline   Reply With Quote
Finally, got started ~ 53flyingcloud Cleaning, Stripping & Polishing 506 06-24-2008 01:57 PM
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 10:26 PM
Clear coat/ plasticoat till Clearcoat, Exterior Paint & Trim 4 12-15-2003 09:43 AM
Condition of Clear coat James Schmidt 1993 Excella 1000 2 05-15-2002 09:23 AM
