Old 02-26-2005, 02:14 PM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Unhappy OK, so how DO you polish the roof?
Is there a good way to polish the roof short of building staging?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 02-26-2005, 02:21 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Post Two Box Vans
Check the search function - saw a great thread recently where an airstream was pulled between two Box vans (about 10ft high) and a couple of ramps were laid between the vans. Two men did the entire roof in a few hours. Impressive!
Tin Lizzie
Old 02-26-2005, 02:52 PM   #3
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I did mine from a ladder - not very much fun, but doable - the two box vans trick is from Insideout.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 02-26-2005, 03:46 PM   #4
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
I know a couple of contractors. Maybe I can "borrow" some staging frames. Won't that make the neighbors happy!
www.balrgn.com
Old 02-26-2005, 04:45 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
That was us! Planning on another get together for a touch up in a couple of weeks. Check out my photo gallery...
Shari
Old 02-26-2005, 06:49 PM   #6
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
That looks like a good way to get at it! Nice job by the way. Love the pics. Looks like ya gt a bit dirty!
www.balrgn.com
Old 02-26-2005, 07:44 PM   #7
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Thumbs down Scaffolding
When we first got our Sovereign last summer, one of the first things hubby wanted to do was get the airconditioner running. However, he did not want to put his weight and the weight of the airconditioner in the same spot (and besides that we already had a broken bow). He devised a scaffolding of sorts made of 2 x 4s that looked like two ladders and a brace and "seat" attached at the top. The bottoms of the ladders flared out a bit to give a little more stability. We were able to move it from one end of the trailer to the other without much problem. He made it so it's easily unbolted and stored in three pieces in the shop.
We removed, serviced and replaced the airconditioner, replaced two vent covers, and cleaned the top while never having to lean a ladder against the trailer.
Sorry I didn't have a digital camera at the time, and our scanner has bit the dust so am unable to send pictures. But if you have any specific questions please PM me.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 02-27-2005, 04:51 AM   #8
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Thanks for the tip! Getting ideas for the summer. (bit cold here to play outside) Plenty of work ahead of me.
www.balrgn.com
Old 02-27-2005, 06:24 AM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
http://www.airforums.com/forum...ghlight=LADDER
Take a look at this thread also. I use a stabilized ladder which gives access quite a bit of my roof, and if it was the next taller model, (and so was I .... I could do even more.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-27-2005, 01:44 PM   #10
The roof "MYTH" continues.
If you need to get on the roof, then do it.
Stay off the segments.
Every, repeat, every Airstream dealer as well as the Airstream factory workers, gets up on the roof.
Use caution, don't jump around, wear rubber sole shoes, walk softly, (it's not necessary to walk on the ribs or stringers), and you will be fine.
Special ladders and or platforms are a waste of time as they are not necessary.
Many, mant years ago, Airstream put 30 mechanics on top of a 30 foot trailer, then leak tested it again. They proved it with photo's.
Results, no leaks, no dents, no problems.
Present type construction has not changed that.
Old 02-27-2005, 02:59 PM   #11
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
I would like to see those old pictures,and old factory pics ,are they online anywhere? Scott
scf31 is offline   Reply With Quote
Old 02-27-2005, 03:15 PM   #12
Those photo's are gone.
Nothing left but great memories.
Not to worry, "IT WAS DONE".
Consider, that if one person on top of the roof could cause damage, then how much damage is caused by the Airconditioner every time you hit a bump?
The answer. None.
The Airstream shell is a lot stronger than people give it credit.
Old 02-27-2005, 05:18 PM   #13
InsideOut's Avatar
1956 22' Safari
Images: 108
If you need to get on the roof, then do it. <snip> Special ladders and or platforms are a waste of time as they are not necessary.
We have been on the roof before, while caulking & repairing vents/skylights...before polishing, no problem. Although getting on the roof while polishing or after will scratch it...thus the solution we had above with the trucks & scaffolding. Had everything, didn't cost anything...was very effective.
Shari
Old 02-27-2005, 07:15 PM   #14
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Angry
Your way seems the smartest. I can't bring myself to get on a 30 year old roof that does not have a problem. Seems like you would be challenging the sealing areas.....
www.balrgn.com
Best Polish to restore Airstream ?? bgow 1969 Overlander 2 07-30-2009 11:04 AM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
