Old 04-14-2014, 08:39 AM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Nuvite vs Jestco
Hi all,
I decided this year to try the Jestco polishing bars and buffing wheel as opposed to the Nuvite paste and Wool Bonnet that I used last year.
I gave it a go yesterday and was not impressed. Every video I've seen online shows the buffing wheel tearing through a layer of gray corrosion to reveal a mirror shine.
Any tips on RPM, amount of bar to use, pressure, etc. I'd like to get this to work but think I am doing something wrong.
Steve
steveirving is offline   Reply With Quote
Old 04-14-2014, 10:35 AM   #2
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I run about 3000 RPM in the wide open spaces. I slow it down when close to trim or lips or anything that the wheel can grab. I don't put much pressure on it, probably little more than the weight of the polisher. I found that new wheels don't cut as well as ones that have been used for a while. Its worked well for me.
Thalweg is offline   Reply With Quote
Old 04-14-2014, 11:44 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Don't start with a wool bonnet with a bar. Use the Jetsco wheel type. Then come back with the bonnet and finish white bar. Actually, the finish up with nuvite and a Cyclo is the best....Jetsco gets it to that point. I start mine this week.
Old 04-14-2014, 08:03 PM   #4
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
For edge wheels. RPM slow, <1200 if you can. Pressure, very little, weight of the buffer is enough. Too much pressure or RPM builds excessive heat w/o improved results. Some very common problems are, a "loaded wheel" the wheel is packed/glazed with alum & compound, happens quite fast with too much pressure & RPM. Edge wheels must be cleaned more often than flat pads but they are easier/quicker. You can buy a cleaning wheel or rake for 10ish bucks. On the edge wheel and bar system you need to match them. Take a look here to get an idea www.buschshineproducts.com .Any whey its done I'd rather get a root cannel!!
putback is offline   Reply With Quote
For Jestco Polish users ALANSD Cleaning, Stripping & Polishing 36 10-02-2013 07:13 AM
Jestco Frustration Northlander Cleaning, Stripping & Polishing 1 05-11-2012 07:24 PM
Anyone tried Jestco Products ? kneal Cleaning, Stripping & Polishing 60 05-22-2010 06:27 AM
Anyone tried JESTCO for stripping and polishing fancy pants Cleaning, Stripping & Polishing 1 03-22-2007 05:54 PM
Rolite or Nuvite? What did you decide? airstreamcaravel Cleaning, Stripping & Polishing 31 10-18-2002 07:14 AM
