Old 03-28-2007, 02:35 PM   #1
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Nuvite, How Much
Just got my order of nuvite, one pound and removal one gallon. How far can I get with it? Grade is F7 but it doesn't look like much to me. How far wil the removal go. I will also be using a porter cable model polisher, any thoughts on that.
thanks
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 03-28-2007, 03:44 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I didn't make it with one pound. However, when I first started, I wasted alot of it by using too much. You just need a little dab every 6 inches or so & you make about a 2 foot by 2 foot section at a time. I found that first you go quickly over the section that you're doing to smear the Nuvite over it thinly, and then you go over it slowly to get down to the shine. Good luck & make sure you wear short sleeves this summer. Your guns will never look better!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-28-2007, 05:15 PM   #3
toastie's Avatar
1955 22' Safari
Great Lake State , .
thanks
James
If I remember correctly, 2 lbs of C, 2lbs F7 and a pound of S, need to order
another pound of F7 for maintenance for this year, have a 17' 1965 Caravel.
toastie is offline   Reply With Quote
Old 03-28-2007, 07:03 PM   #4
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
wow - a pound should really do it unless its really badly oxidized - less is better when polishing these things - less Nuvite and less speed on the polisher.
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is online now   Reply With Quote
Old 03-28-2007, 07:37 PM   #5
1970 27' Overlander
Houston , Texas
I will post my progress, I am so excited to get started it just doesn't seem like near enough. My 82 year old mom volunteered to sew the new curtains for me too.
James
____________
1970 Overlander
Old 04-02-2007, 07:30 AM   #6
1970 27' Overlander
Houston , Texas
Polishing?
I stripped the plasticoat off the front curb panel. It came right of with a gentle hosing after setting for an hour. Proceeded to polishing, I have a Porter Cable 7424 model orbital polisher. I put on a wool bonnet and put a dab of F7 on. I smeared the polish slowly and started to polish. My problem seems to be that when I apply pressure it does not spin sufficiently and when a back off on pressure it spins but not enough pressure to polish. I tried going slow at about the 3rd setting and then up to about 6, it never heated the skin at all. It does look better and semi polished but I was hoping for better results. I am not sure if its the technique or do I need a heavier grade. I feel that I need a different polisher altogether as I am not getting a good spinning with this one? Any help is appreciated.
James
____________
1970 Overlander
Old 04-02-2007, 08:40 AM   #7
1968 26' Overlander
Marshall , North Carolina
jsflint,
If I read correctly you are putting the Nuvite on the bonnet. Try putting the polish directly on the aluminum, a fingerprint amount every 3-6 inches, then try buffing. Only try a small area at a time, say 1-2 sq. feet. It will be trial and errror until you figure out exactly how much to use. If oxidation is excessive you may have to go over the same area more than once.
Hope this helps.
Hank A is offline   Reply With Quote
Old 04-02-2007, 08:45 AM   #8
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We used a Milwaukee #5460 Dial Speed Control Polisher for compounding, it worked great.
You still need several passes to get at all the oxidation...
I believe what you are using is more like a single headed Cyclo Polisher - I don't think it's going to do the trick for the deep-seated oxidation. Try a buff on a drill or the Milwaulkee polisher - they have more tooth.
The Porter Cable that you have may work for the later stages, for getting rid of some of the swirls.
Shari
Old 04-02-2007, 08:58 AM   #9
1968 26' Overlander
Yes, InsideOut is correct....the orbital will not cut the oxidation like a rotary. You will be polishing for a long, long time with it.
I don't know if it is any good, but Harbor Freight advertises a variable rotary buffer/polisher for under $50. I bought an off brand locally for under a $100 and it works very well.
Old 04-02-2007, 08:59 AM   #10
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
The info above is all right on target.
One further tip that worked for me: After you dab on the compound using your fingertip, use the polishing pad to smear the polish around a bit before you turn it on. This helped prevent slinging polish off by knocking down any small globs that tend to fly away.
I used the Harbor Freight circular polisher with good result ($39) and used a cyclo on the final polish.
Here are 3 sites to check some other's experiences and suggestions.
Dave
Polishing
Home
Polishing information
Fyrzowt is offline   Reply With Quote
Old 04-02-2007, 06:37 PM   #11
1970 27' Overlander
Houston , Texas
What a difference the right tool makes!
Hi All
Could not wait to get home this afternoon and test again, I can't tell you what a difference the right tool makes so I will show yall. Here is a couple of pictures after about fifteen minutes of polishing. It is hard on the hands but like someone else posted, very addicting. Thanks for all the replies as now I am getting the results I was hoping for.
James
Name:	Airstream Polish Frnt.jpg
ID:	35051   Click image for larger version
Name:	Airstream Polish Frnt2.jpg
Name:	Airstream Polish Frnt Close.jpg
____________
1970 Overlander
Old 04-02-2007, 07:11 PM   #12
InsideOut's Avatar
1956 22' Safari
Images: 108
That's more like it!!!!
Yeah! Glad it's working out better for you...what are you using now?
Happy Polishing!
Shari
Old 04-02-2007, 07:20 PM   #13
1970 27' Overlander
Houston , Texas
I am using a borrowed black & decker 6138 7 inch sander/polisher with the polishing bonnet. Speed can vary from 0 - 3000. I'm polishing as instructed from previous posts with very low (manual) speed and very little polish. Just sorry I did get the weekend to polish.
James
____________
1970 Overlander
Old 04-02-2007, 07:22 PM   #14
InsideOut's Avatar
1956 22' Safari
Images: 108
Perfect! The right kinda tool...
Just sorry I did(n't) get the weekend to polish.
James
Shhh...don't tell anyone, but I think there's another one coming!
Shari
nuvite polish arjo Cleaning, Stripping & Polishing 2 03-06-2006 10:17 PM
rolite vs nuvite nevisstudio Cleaning, Stripping & Polishing 1 08-01-2005 04:47 PM
Where is the "best" (least expensive) place to buy Nuvite? 72Blazerod Cleaning, Stripping & Polishing 4 03-12-2005 06:30 AM
How much Nuvite F7 and S do I need to polish a 16.5 ft'er 72Blazerod Cleaning, Stripping & Polishing 6 03-02-2005 08:49 AM
Rolite or Nuvite? What did you decide? airstreamcaravel Cleaning, Stripping & Polishing 31 10-18-2002 07:14 AM
