Old 10-28-2007, 12:32 PM   #1
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
NU-FINISH polish
Just to add my $.02, I've found that NU-FINISH car polish is an easy product to apply. You can even apply it in direct sunlight, and it goes on and wipes off very quickly. While it won't cover scratches (e.g. from branches), it adds a nice glass-like finish to our freshly-washed Bambi.
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 10-31-2007, 08:50 PM   #2
holland , Michigan
I agree wth you NU is a great product and easy to work with. It also will perform up to one year after application. BUT, my 04 28 safari had a brand new bottle of waubernize from previous owner/ in chula vista ca on a 7k tour and we decided to use the unused formula. I was impressed indeed, with excemption to the rock guards.. Here wd40 worked the best. the old wauber really cleans as good as it does polishes. did the entire rig i less than 3 hours, went to the hot tub and relaxed at the chula vista rv resort. Not bad for the close location to San Diego.She looks better than ever.
safari 28 is offline   Reply With Quote
Old 11-02-2007, 10:29 AM   #3
ESCAPE POD's Avatar
2007 19' Safari SE
Yeah, the NU just streaked on the rock guards. Then I remembered that they are stainless steel. Thanks for the wd-40 tip!
Jerry & Susan
Old 11-02-2007, 11:52 AM   #4
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Plexi
NU FINISH also works great on the solar rock guards, AKA plexi window guards.
Michael
ArtStream is offline   Reply With Quote
Old 11-02-2007, 12:57 PM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Umnn - Consumer Labs liked the Nu-Finish in their testing & reported it a best buy but they never admitted what its like to re-apply it a year later - its just a mere 1000% more work since the good protective film turns into a substance similar to Vulkem when the next' years applicator hits it.
If on second application you commit to using 3x the regular amount of new wax to act as a solvent and a huge stack of terry cloth wiper towels to keep the old now-dissolved wax from 'polluting' the surface by wiping it off immediately while still wet then re-applying the true finishing coat you will do okay...
I have used Nu-Finish since it came out around 1980 and I learned how hard it was to re-apply on my 1971 Ford Pinto and haven't bought it since. I perfected the above mentioned method when my great-uncle had me help him recoat his $50,000 Lexus after he read the Consumer Labs article....
Old 11-02-2007, 04:16 PM   #6
ESCAPE POD's Avatar
2007 19' Safari SE
Reapplication woes: NU-FINISH
Since you aren't a current fan of NU-FINISH, what product do you use to polish/wax your Airstream? Walbernize?
Jerry & Susan
Old 11-02-2007, 04:36 PM   #7
1975 27' Overlander
High River , Alberta
My father used mineral oil to clean stainless steel. Something he learned working in the food industry.
AlbertF is offline   Reply With Quote
Old 11-02-2007, 05:05 PM   #8
_
mineral oil is a nice product to clean/coat the stainless segment protectors...
many of the brand name sprays for brushed stainless are basically food grade mineral oil...
nu-fin...
the msds isn't complete for this product but it is 10% stoddard solvent...
and that's the primary 'cleaner' agent (white mineral spirits) it contains....
ATSDR - ToxFAQs™: Stoddard Solvent
http://www.public-health.uiowa.edu/b...%20solvent.pdf
White spirit - Wikipedia, the free encyclopedia
i have tried it but don't use it or recommend it. yes cr DID give it a big THUMBSUP a few years ago, but so what, they also like honda and dell
generally most solvents applied to the new alcoa clearcoat are safe, but on the older plasticoat would be detrimental...
whenever using a petrol distillate solvent, wear gloves, work outdoors and stop exposure IF the listed symptoms begin....
the newer water based poly sealants are clearcoat friendly, durable and so on...
cleaning, polishing and waxing/protecting are better split up into separate steps...
cheers
2air'
Old 11-03-2007, 04:39 PM   #9
Wabbiteer's Avatar
1972 29' Ambassador
I am not disrespecting Nu-Finish - seeing how gnarly the film is EVEN after it gets diluted by road grime oils and tree saps is impressive, the somewhat rubbery film is still protecting the paint. Just communicating a plan of action for when the real work starts recoating the vehicle.
For my tow vehicle I use one that does some neat things with UV light - gives a 'optical purple' sheen to it from skyshine on the horizontal planes - I will get the name next time I am out back.
I tried above wax on freshly polished taillight castings on my '73 and have powdery white oxide stains after three weeks - I guess it's time to get the Nu-Finish out, IF someone doesn't have a better option....
Old 11-03-2007, 04:45 PM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Liquid Glass will do what the NU stuff does, and will easily be reapplied when neessary. Its a poly coat over your aluminum, paint or clearcoat. I have been very happy with its performance over the past 5 years.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
to polish or not to polish that is the question Frank's Trailer Works Cleaning, Stripping & Polishing 17 08-26-2007 11:15 AM
To Polish or not to Polish, that is the Question? mello mike Cleaning, Stripping & Polishing 14 03-22-2005 11:28 AM
Name that finish! Stefrobrts Upholstery, Blinds, Walls & Interior Finishes 3 05-27-2004 11:55 PM
exterior finish Roland Clearcoat, Exterior Paint & Trim 2 06-24-2003 01:04 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
