Old 09-30-2013, 05:58 PM   #1
1976 31' Sovereign
1970 21' Globetrotter
New York , New York
Nooks and crannys
Can anyone suggest a tool to polish small areas that you cant get a large buffer in? The dremel is too small a polishing pad, they don't last long and are expensive.
Marbeltown is offline   Reply With Quote
Old 09-30-2013, 07:00 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
They make polishing pads for drills ...
Amazon.com: drill polishing kit: Automotive
reinergirl is offline   Reply With Quote
Old 09-30-2013, 07:26 PM   #3
mapleton , Utah
Get an inexpensive air powered 1/4" die grinder, use the same wheels designed for drills but turn the speed down a bit. Better speed than a drill. Harbor Freight sells a small polishing set with compound for about $3 on sale regularly and it works great in small/awkward places.
tim
rumrunner is offline   Reply With Quote
Old 09-30-2013, 07:57 PM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Just the Ticket
The smallest polishing solution we have come up with is to use a Dremel tool...we use the new 4200 with quick connect and 1/8" buffing attachments from:
Shank-Mount Buff Bobs - TP Tools & Equipment
These will do a fine job in tight spaces such as between the lettering on the end caps.
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
