Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 05-17-2010, 03:26 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
Newbie question - how do you get up on roof to clean your AS?
Hi there -
We just bought an 08 Safari 23FB and want to wash/wax it in the next few weeks.
I've read the instructions on how to wash/wax but I am wondering how y'all usually get to the roof to wash/wax it?
Do you use tall aluminum ladders and actually get up on the roof to clean that area and wipe it down - just pad under the ladder to avoid scratches or do you just use a cloth/broom type handle to wash and wipe down those areas and stay off the roof?
Can the roof support a person without buckling/getting dents?
Thanks!
bonginator is offline   Reply With Quote
Old 05-17-2010, 04:35 PM   #2
Retired.
. , At Large
I use an aluminum ladder with towels wrapped around the part that would contact the trailer. If the trailer has an awning or two, I place the ladder against the metal slats that cover the awning.
A soft bristled brush will work on the roof as well as the sides. The roof will support people on it, just keep to the lines of rivets (that's where the support is), and keep off the ends.
Old 05-17-2010, 04:39 PM   #3
Kevin245's Avatar
Yes the roof can support your weight but there are some important considerations.
Wear flat, soft sole shoes and stay on the rivet lines. Never walk on, or try to access the roof from the end caps.
We don't actually get on the roof to wash it, we use a long handled mop. We do access the roof to re-seal any seams, penetrations, and visually inspect the plastic parts twice a year. I use a large step ladder and I know of others who use a straight ladder resting on pads or a board that spans the rib lines.
Regards,
Kevin
William C. Swinney
Old 05-17-2010, 05:32 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I put a ladder against the awning(s) to reach the top with a long handled brush. I do get on top for maintenance work, but I wear soft soled boat shoes and stay as close to the rivet lines as possible. NO ENDCAPS. FWIW I am no lightweight at 215#.
Aaron
WBCCI #XXXX AIR #2495
Old 06-25-2010, 11:58 PM   #5
howco's Avatar
1970 27' Overlander
Sumner , Washington
bonginater
Thanks for asking, I just bought my first a/s a month ago and was wondering the same thing.
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Newbie with a roof leak JackP Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 05-06-2009 10:20 AM
Newbie with a roof leak. Please Help! JackP Member Introductions 0 05-04-2009 07:52 PM
1969 31' Clean roof crusty build up CJ of Okla Cleaning, Stripping & Polishing 3 02-10-2007 10:49 AM
Another newbie question... fan on roof??? flamingo-kid1 Roof Vents, Skylights & Fans 5 07-27-2003 09:12 PM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
