Old 10-21-2011, 11:49 AM   #1
castle rock , Washington
Newbie needs to strip & polish
The more I read the more questions I generate. I have decided on CITRISTRIP from HOME DEPOT. Accourding to those using it it performs as well as any. And is cheaper. I will take the word of those that have actually used both which have posted comments to the same.
However one member that is often seen on the boards indicated the once the unit is stripped you need to polish it each month?
What have you experienced with the need to polish after stripping.
Secondly what product have you used and how does it compare to the others you have used.
Thanks so much for reading!!!
Bill
1969 AS
billy1davis is offline   Reply With Quote
Old 10-22-2011, 09:08 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
I'm using CitriStrip. No problems like others have posted here about Jasco. Seems Jasco hardens if you're not careful. Too much time on the clearcoat, and it hardens. I've had CitriStrip on sections of mine overnight (roof paint over clearcoat) and walked out next morning, fired up the pressure washer, and it all washed off. Working LONG hours with my job, so I've only stripped the front and end caps of my Airstream motorhome. Tomorrow is polishing day. All that I've talked to here on the forum, have used Nuvite, available from vintagetrailersupply.com. Found something called Truck Box Polish at Lowes. Not cheap, $15 for a small 12 oz bottle. Have used it on aluminum bumpers and it's working great. Will buy the Nuvite Grade S when it's available in the 1lb bucket on vintagetrailersupply. Most have stated that when polishing, it takes a bunch of polishing, no matter the product.
Also, once Airstream is polished, a minimum of polishing again every 6 months is required, some go so far as to polish quarterly.
Hope this helps.
Thanks, Derek
Strip & Polish 89 Excella 32' cjack99 Cleaning, Stripping & Polishing 14 04-06-2012 10:03 AM
Strip and polish in the seattle area? Naterezac Cleaning, Stripping & Polishing 0 07-06-2011 01:45 AM
Polish a 1984? casa3805 Clearcoat, Exterior Paint & Trim 11 06-26-2011 09:13 AM
Interior Wall Structure Strip chowman2011 General Interior Topics 3 05-17-2011 08:09 AM
Seal or Polish first JIMandPJ Ribs, Skins & Rivets 4 03-14-2011 11:58 PM
