Old 11-17-2013, 04:22 PM   #1
TMT
TMT's Avatar
1974 23' Safari
2005 22' Interstate
Jacksonville , Florida
Need help Removing an Emblem
Iím having a problem removing a very large stick-on emblem the PO placed on the upper front curbside panel. It is about 12Ē in diameter. A silver ďseal of the state of NCĒ. Nothing wrong with that, itís just that her new home is in Florida.
I just canít get it off. Iíve used goo gone, goof off, paint thinner, mineral spirits, and the PR-5044 peroxide activated stripper we used to remove the clear coat. I havenít tried wet sanding as I am hesitate to scratch it too much.
It is a stubborn emblem, just wonít let go. Please, Iím available to all suggestions. HELP!!!!
And Thanks!
TMT is offline   Reply With Quote
Old 11-17-2013, 04:35 PM   #2
1955 16' Bubble
claremore , Oklahoma
TMT,
Just spent quite a few hours removing factory vinyl decals and pinstripping from my 1994 Roadtrek class B. My son and I used a heat gun to warm up the decal adhesive,then a plastic "puddy knife" to scrape and peel the decals. Then,we soaked (and tried EVERY adhesive remover known to man) to remove the residue.(denatured alchol worked OK) Taping a rag soaked with the remover and allowing time for penetration helped.....note....not responsible for any temper tandrums you may have while doing the job!....walt...tulsa,ok
walt c is offline   Reply With Quote
Old 11-17-2013, 05:02 PM   #3
helmsman's Avatar
1967 22' Safari
Long Beach , California
Hello TMT
I believe it was Inland RV that mentioned how to remove the numbers from an airstream. They recommended putting a wet towel over the number, then applying a hot iron. I used this method to remove my old numbers and it worked like a charm. You might give it a try! - I hope you get it off without harm. -- Don
helmsman is offline   Reply With Quote
Old 11-17-2013, 05:22 PM   #4
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
You could use one of these - pinstripe eraser wheel. You can buy them at auto parts stores in the body repair supplies area.
robert claus is offline   Reply With Quote
