Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 06-13-2007, 11:21 AM   #1
rebel beck
rebel beck's Avatar
Profile:  1975 31' Sovereign
Oxford , Mississippi
Images: 35
Need Help with Polish
I started polishing and now I have a problem and hope someone that has had the same problem will chime in. Our trailer is a 75, but sometime thru the years a couple of panels where replaced 2 on the end, 2 on the front and the door. So last night I started working on the door with a few passes of the Nuvite 7 I could tell it was just not cutting down to the mirror look like the rest of the trailer. I'm sure it can shine but how? Now I'm real worried I'm going to have a 2 tone trailer.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 06-13-2007, 11:38 AM   #2
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
I have noticed something simmilar on my 68, I have also read here that you can expect differences from pannel to pannel. So I suspect that you dont have to much to be worried about. Some areas of the trailer will take more passes than others is my (limited) experience. Good luck with the project!
Rodney
On a magic carpet ride
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 06-13-2007, 12:16 PM   #3
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
1975 units are plasticoated. Are you sure you have chemically removed all the Plasticoat before you started polishing?? If not it will never turn out the same. Even if you did remove it there might have been a switch in the alloy of the alumimun that was used for the repairs. Some just need more polishing other alloys do not polish as well no matter what you do.
Old 06-13-2007, 01:15 PM   #4
rebel beck
rebel beck's Avatar
Images: 35
Yes the clear coat is stripped.
Becky
Air# 9552
Old 06-13-2007, 02:28 PM   #5
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
So the portion you are trying to polish on your door...it's a replacement section? Right?
If so, it's probably a different alloy of aluminum as others have mentioned. We have a small patch on our street side that is a different aluminum composition...it'll never polish the same as the original panels. You can buy the "right" aluminum when doing repairs, but a lot of people don't because it is not as readily available. It may look okay when new...but it oxidizes differently and discolors over time.
It's a chemical composition thing...like comparing 12kt gold to 18kt gold...yes, they both are considered "gold", but the actual composition is 12 parts or 18 parts real gold (of 24 total parts) and the remaining is "some other metal". So 12kt has 50% gold and 50% something else and 18kt has 75% gold and 25% something else. They look and polish differently because the "something else" effects it.
Have you started polishing the other replacement sections? Do you know if all the replacements were done at the same time with the same materials? Are you having as much trouble with them?
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 06-13-2007, 04:40 PM   #6
rebel beck
rebel beck's Avatar
Images: 35
Shari,
I have only done the door, now it looks kinda shiny but has a mat look to it, if that makes since, I'm going to talk with Tom at Perfect polish and see what he can suggest at this point. I have noticed newer trailers that are polished and they look great so I'm thinking there is some way to get it to match or come pretty close.
Becky
Air# 9552
Old polishers take note Bradjun1 Cleaning, Stripping & Polishing 3 06-08-2005 05:06 AM
meguiars polish david h Cleaning, Stripping & Polishing 3 01-11-2003 01:42 PM
polish a brushed trailer? john hd Cleaning, Stripping & Polishing 6 08-25-2002 11:03 PM
Best Polish to restore Airstream ?? bgow 1969 Overlander 1 08-06-2002 11:23 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 08:15 AM
