Old 10-08-2010, 08:43 AM   #1
1970 23' Safari
1973 25' Tradewind
raynham , Massachusetts
My brother used steel wool on my airstream *eep
"Hey sis, want some help?" My reply, "Maybe, I'll let you know." ugh
I show up this morning and one side looks great and asked him what he did (even though I hadn't given him the go-ahead) ... Steel wool, from what I understand steel impregnates the aluminium, now what should be done to fix this?
deelind is offline   Reply With Quote
Old 10-08-2010, 08:47 AM   #2
Exactly where was the steel wool used, and what was the intended purpose?
Old 10-08-2010, 09:01 AM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Impregnates? Maybe you'll get a Bambi in about 9 months.
If it "looks great", what is it you want to fix? I imagine a traditional polishing job using Nuvite (or similar) products, and a lot of your bro's elbow grease, would bring the trailer to a perfect shine if you now have visible scratch marks from the steel wool.
tphan is offline   Reply With Quote
Old 10-08-2010, 09:10 AM   #4
1970 23' Safari
1973 25' Tradewind
He used Nuvite C with the steel wool on the exterior (sorry I hadn't said that) and it does look great, but for how long if it is said that steel wool impregnates the aluminium.
From what I've gathered, steel wool is a non-no. I did start with the F grade, 2nd step with C but it was still looking cloudy which I had hope would be taken care of by the final polish. Being a newbie, I must say I'm a bit overwhelmed with the various methods for restoring the exterior finish.
Old 10-08-2010, 09:12 AM   #5
1970 23' Safari
1973 25' Tradewind
hahhaha! " Impregnates? Maybe you'll get a Bambi in about 9 months." I wish that were true! On a side note, Airstream just opened up a dealership a few miles away, think I'll go have a look at a new one just to torture myself some more.
Old 10-08-2010, 10:26 AM   #6
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
You may want to wash with a mild solution to
get any small metal residue off...steel wool
rusts very quickly.
kennethowens is offline   Reply With Quote
Old 10-08-2010, 10:53 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have used steel wool at times to start on something really bad, well actually Brillo pads.
Then went on to polish normally and no crisis resulted.
Actually have resorted to #80 sandpaper a couple times
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-08-2010, 11:28 AM   #8
2002 19' Bambi
Lafayette , California
Surely there will be plenty of answers from the no-no steel wool group. Despite that, I think you have little to worry about as long as there are no visible shreds of steel around rivets and such. Walbernizing or waxing the now-polished surface will help remove any remaining crumbs or shreds of the steel wool.
Several years ago I used lots of steel wool to polish the aluminum hull of a rowboat my father made in about 1950. Since then the bare aluminum of the hull has been upside down in rain and in the dry without one (yes, not one) spot of rust on it.
Tim
Tim A. is online now   Reply With Quote
Old 10-08-2010, 02:22 PM   #9
1986 32' Excella
vledder , drenthe
Images: 8
I also use steel wool
On the roof I started with OO and the finish with OOOO
I used it together with gord polish
remcolent is offline   Reply With Quote
Old 10-08-2010, 08:34 PM   #10
Southwestern , Ohio
Not a problem
The concern is that particles of the steel wool will embed in the soft aluminum and then rust. I used steel wool on some areas of our '60 Pacer to get the aftermarket clearcoat off and then followed by Nuvite F7 and finer grades.
Had the trailer for a few years after that and never saw any traces of rust from the steel wool. I wouldn't worry about it.
Nuvite-F is offline   Reply With Quote
Vintage Airstream on Hooked Wool Rug Roamin Cat General Interior Topics 12 05-21-2010 07:55 PM
Gen Disarrays brother Boondocker Off Topic Forum 26 07-23-2009 08:31 PM
New Big Brother juel Off Topic Forum 26 09-25-2007 07:08 PM
compound/steel wool ? gmprejean Cleaning, Stripping & Polishing 5 07-11-2004 07:47 AM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
