Old 05-07-2005, 10:22 PM   #1
AirHeadRik's Avatar
Castaic , California
Images: 13
More Polish Info!
O.K., I am stoked to report that when you use an acid bath, the compounding procedure goes waaaay faster. Now, there are some that would argue that acid washing will cause leeks. Many, many pros who polish Airstreams and Aircraft use acid wash, so, I'm not worried. If you are worried, well, don't do it. (Anyone personally know anyone who acid washed and now has leaks?) I think the key is to do one section about 3 feet x 3 feet or so at a time.
I plan on actually video taping some tests tomorrow. I also tried a green rouge formula today and it works pretty well. No better than Heavy Metal, though and about the same as Nuvite but, with more of a mess.
Also, I picked up a Makita Polisher/Sander that turns all the way down to 600 rpm. My other one was about to die. This thing makes the job go much better.
AirHeadRik is offline   Reply With Quote
Old 05-08-2005, 04:49 AM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Thanks for keeping us posted with your progress, BD. It looks like you're doing a great job on your Bambi II.
I'm curious about your coach, I don't see any clear pics of the streetside on your homepage, but it appears to have 3 windows on that side.
All other Bambi II's I have seen had 2 windows there. Do you think that was a custom order or maybe a previous owner upgrade?
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 05-08-2005, 08:29 AM   #3
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
hello,
about the acid I do not feel worried, I was working as a wash trailer tank, and we used acid bath without any problem.
Some advice about the process : spray acid and few seconds later rince with water. Do it with someone else who follow you with 10 seconds delay.
Sorry for the english, i hope you anderstand me,
otherwise someone can try to translate my post... oups
dufferin is offline   Reply With Quote
Old 05-08-2005, 09:21 AM   #4
AirHeadRik's Avatar
Images: 13
Cali model?
I think it is a California made model and that is the difference. I believe I had heard someone talking about that.
Old 05-08-2005, 12:48 PM   #5
bigshinything's Avatar
1962 16' Bambi
Images: 8
This is a reflection, notice the rivet. This is the depth of shine I got with Nuvite and an acid wash. Some "Before" pics in my photo section.
bigshinything is offline   Reply With Quote
Old 05-08-2005, 05:30 PM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
what type acid are you all talking about? Is it like Kleen Strip or what. (Or should I try to call Timothy Leary)
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-08-2005, 06:22 PM   #7
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
Dufferin, your English was perfect until you got worried about it! Bienvenue!
So, looks like Dufferin and BigShinyThing both had sucess with acid wash...not acid trips (nudge, nudge, wink, wink, Alan)...Those results look great!
Mary
Our Airstream adventure continues!
Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Old 05-08-2005, 08:42 PM   #8
AirHeadRik's Avatar
Images: 13
I got this stuff at a truck wash place that is for aluminum. Looks like a local mixture. I know "aluminum brightner" works well from other folks.
Old 05-11-2005, 05:28 AM   #9
In support of your acid bath-
I asked the airport people about it before and said there was theory about the leaks, the rivets and the destruction. It brought laughter. They've been using it for years and the rivets on the planes haven't fallen out, the seams didn't start flying open. The stuff they use was actually called "Aircraft Cleaner" and I think its absolutely safe.
Its almost as if there are forces who don't want us to do it the easy way. If you can acid wash, light wet sand, use a couple passes of home made rouge or other less expensive rouge based polish such as HM- nuvite and cyclo are history. The other polishing industries aren't using them- this is there stronghold- a cottage industry that they are defending.
TravelCloud is offline   Reply With Quote
Old 05-11-2005, 06:47 AM   #10
Rog0525's Avatar
Images: 11
Here's a novel idea: Why don't you polish your trailer the easy way and expose those evil forces once and for all?
Rog
Old 05-11-2005, 06:54 AM   #11
I will-
Just have a lot of other priorities beforehand, but in the meantime, guys like Ed are exposing it- and I don't know about evil, but greed sure comes to mind...
And just because someone else did it, I reported and commented about it, doesn't mean that it doesn't exist.
I still haven't picked my method, and don't want a patchwork of attempts. But don't worry, I'll get to it...
Old 05-11-2005, 08:50 AM   #12
AirHeadRik's Avatar
Images: 13
I want to put emphasis on how great this Makita Sander/Polisher works. The fact that it is angled makes it soooo much better to control than a drill. The drill is a nightmare compared to this and it turns slower! Really great!
Old 05-11-2005, 10:17 AM   #13
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I swore I wasn't gonna get involved, but....
I've been around small airplanes for a long, long time.
airplanes leak.
alot.
in fact, I don't think I've ever been in an aged airplane that doesn't leak at least a little bit...somewhere. sort of like trailers, in that its not a question of "if" it springs a leak, but when.
anyway, its not a huge deal, as they don't have plywood floors. but it is a recurring theme amongst aircraft owners.
but perhaps using the acid bath is a contributor? who knows....my dad's airplane desperately needs an acid-bath, followed by a paint job. its never been done to it. but it leaks anyway.
maybe its just what happens when you rivet 2 pieces of alluminum together, given enough time and exposure to the elements.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-11-2005, 10:28 AM   #14
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Airstream seams do need to be resealed occasionally. I have done it to mine and stopped some leaks. I would be more concerned about chemicals getting into the seams and staying there, causing adhesion problems in the future when you reseal the seams.
Stephanie
Best Polish to restore Airstream ?? bgow 1969 Overlander 2 07-30-2009 11:04 AM
Other A/S info sharing sites Rog0525 Our Community 12 10-18-2002 10:09 AM
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 01:08 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Airstream info Rodger Airstream Motorhome Forums 3 07-03-2002 09:15 AM
