Old 03-21-2014, 09:32 AM   #15
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by 50KIP View Post
A warning about "mirror" finishes: My neighbor boondocking at Quartzsite, AZ, had a 28' AS that he had polished to a mirror finish. The sun's reflection off the trailer created burn holes in the ground cloth next to the trailer; a real fire hazard.
Yep...and you can fry an egg! I've done it...
Shari
Old 03-21-2014, 07:47 PM   #16
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
I can understand the glare off an shiny trailer being an issue. I'd just like to get rid of the milky/crazed finish. If it gets a mill finish, more matte, I'm fine with that. We also have some weird spots where shrubs rubbed against the roof while the trailer lived in our backyard in Oakland. I figger I can strip the coating and then at some later point in time, buy a buffer and dive into it.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-22-2014, 09:09 AM   #17
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
Originally Posted by beckybillrae View Post
None of the Airstreams have ever been anodized. Avion had them, along with several other defunct aluminum trailer manufacturers, but not Airstreams. A satin finish is what a 1974 trailer has. If the clear coat is shot (peeling, or wearing through), you will still have a satin finish if/when you remove the clear coat. A mirror finish was never manufactured at the factory, but accomplished by people who have done it themselves, or had a professional service do it. It's a long, tedious process that can be accomplished, with the right tools, by anyone determined enough to do it! Hope that answers your question.
Thanks Becky, my mistake!
Leonie
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
Old 03-22-2014, 09:44 AM   #18
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
I love the look of the polished ones but is it possible to repair just the failing clear coat with out having to strip the complete in my case coach. Mine is failing on the roof and end caps and about 6 inches below the awning.
The sides are in good shape, I cleaned the oxidation on the sides with plastic headlight polish and a buffer and they are fine. I would like to the failing clear coat but not quite sure how to do it with out making it look worse.
shepherd57 is offline   Reply With Quote
Old 03-23-2014, 10:49 AM   #19
Globie64's Avatar
Images: 18
I've wondered about that, trying to repair a failing finish on a lot of things. I think with a plastic finish, it's probably impossible to do. If you go over it again, it'll look weird and lumpy. You can't really re-liquify it to smooth it out (always my concept, I think it works with varnishes and oils on wood). Maybe contacting one of the professional Airstream restorers to see what they'd do?
diamond satin clear coat arden_dean Clearcoat, Exterior Paint & Trim 26 02-08-2014 10:22 PM
2008 AS interior wall finish gebo General Interior Topics 1 09-16-2011 12:05 PM
How to attain a uniform dull finish. mikeandnora Cleaning, Stripping & Polishing 9 08-04-2011 05:49 AM
matching aluminum... finish color choices funkill Upholstery, Blinds, Walls & Interior Finishes 1 06-13-2011 03:06 PM
ReJex Polymer finish nm1oqrz Cleaning, Stripping & Polishing 3 06-08-2011 03:19 PM
