Old 08-02-2015, 07:53 AM   #1
bap-n-nan's Avatar
olive hill , Kentucky
mineral spirits, tar on a '63..
hello all, im new here and working on our first AS ..the po had put a heavy bead of tar over the door eyebrow probably for an awning or something i had some mineral spirits and plastic scrapper is this safe to use on my 63 overlander------the tar has to go i tried a little and it worked but then i thought will it hurt my camper...? so i thought i would ask you guy,s and gals before i proceed,,,,,,thanks in advance for any and all suggestions,,,
bap-n-nan is offline   Reply With Quote
Old 08-02-2015, 07:57 AM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
It won't hurt the aluminum. Your clear coat is probably gone by now (if there ever was any). I clean my trailer with mineral spirits all the time when I polish.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-02-2015, 08:07 AM   #3
bap-n-nan's Avatar
shewww thank god,,,,------and thank you sooo much for your quick reply,,,,going out now to get rid of the rest of it....
again thank you so much...
Old 08-02-2015, 08:45 AM   #4
Central , Mississippi
I've had luck with a heat gun loosening the big pieces, followed by mineral spirits for a final wipe down.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-02-2015, 08:53 AM   #5
bap-n-nan's Avatar
thanks HIHOAgRV,,,i have a heat gun will try that aswell it is about 4ft long x 3 inches wide with some places being an inch or more tall,,,---this morning i can see where the mineral spirits was used but i plan on giving it a polish afterwards anyway,
again thank you very much...
Old 08-02-2015, 09:20 AM   #6
57BB's Avatar
1964 26' Overlander
1954 29' Liner
Washington , Washington, D.C.
Home Depot sells a stripper called Ultra Strip. Non toxic green product that I use to remove everything, paint, tar, adhesives. The trick is to let it sit on the surface for several hours then use a plastic scraper to remove the debris. It's a miracle product that I've used dozens of times on multiple trailers with great success.
57BB is offline   Reply With Quote
Old 08-02-2015, 09:23 AM   #7
Denis4x4's Avatar
Durango , Colorado
WD-40 also works
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Old 08-02-2015, 09:40 AM   #8
bap-n-nan's Avatar
thanks folks,,,,--i will remember all those things,,---but i have a gallon of spirits as of now,,,but all greatful for your helpfull products,,,----im interested in everything and eager to learn all about the AS as i can and will help anyone i can when i can...
the wife and i have restored several vintaage TT,S but this is are first AS.--and we love it...she has a wonderfull dent free body--even at 52yrs old,,---i wish i still looked as good----lol
thanks again..
Removing mineral deposits on exterior utahredrock Cleaning, Stripping & Polishing 4 08-02-2009 09:24 AM
Avoid Mineral Spirits / Petroleum Products? MartyK Cleaning, Stripping & Polishing 9 11-26-2007 05:24 PM
Aluminum Spirits FreshAir Off Topic Forum 3 10-30-2006 09:12 PM
Polishing/mineral spirits davidz71 Cleaning, Stripping & Polishing 13 08-07-2005 07:43 PM
Holiday Spirits 53flyingcloud Our Community 30 01-01-2003 01:22 AM
