Old 01-12-2007, 04:42 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Metalwax Trial
We're in Miami and looked at my odometer, it's reading 2300 miles since leaving NY on the 2nd for Topsail.
This is not just a maiden trip with the new AS it's looking like a journey.
I was supposed to leave for home tomorrow but with bad weather coming in to the North east I have to suffer and stay here til Wed.
It will be 1,600 miles home so about 4,000 miles for my my first RV experience.
'77 Sovereign Intl 31' CB
Old 01-12-2007, 04:50 PM   #2
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
And the award goes to . . .
Bob, I think you get the award for perseverance in Airstreaming. You've accomplished so much in so little time with your rig, got it roadworthy, camping ready, got an awesome TV and by gosh . . . . you haven't let anything stand in your way as you click off the miles. Wally B would have been proud. It'll be good to see you at the Springstream.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Aluminocentricity
Sugarfoot is offline   Reply With Quote
Old 01-12-2007, 05:22 PM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Thanks, now we want to get it to look as shiny as yours.
We found a paint remover that works easy.
have have of it done. Tomorrow I start polishing with the Metalwax.
Old 01-12-2007, 06:16 PM   #4
raptorron's Avatar
2006 16' International CCD
Kennesaw , Georgia
Bob,
How is your "frige" doing? I forgot to ask the morning we left. With the winter weather working its way east, I hope the "live rock" will do O.K. Hope Cathy is doing well.
Now for the big question: Did the "Majic Beads" perform? If so , let us know as they will soon be in every Airstream tire in the country.
...............ron
Ron & Cindi
Air # 13727
2006 Bambi Quicksilver
T/V 2007 Yukon Denali
raptorron is offline   Reply With Quote
Old 01-12-2007, 08:04 PM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Originally Posted by raptorron
Bob,
...............ron
Hi Ron & Cindi, Cathy is back to herself for the past two days or so.
We put about 800 miles on the Dyna Beads and the trailer now floats over the road MPH has improved by 35%, and the tires look very happy
I really can't tell the difference, because I'm not in it when driving,
when I get home I'll have someone drive it and get into the trailer for a few minutes to feel for and vibrations on the floor or wheel wheels.
I'm waiting on the rock till the weather is better up north.
I'm stuck in this place now I need sun block, next week in NY the forcast is for 16 degrees
The fridge is working great
I guess we'll see 'ya in GA.
Old 01-13-2007, 06:05 PM   #6
Images: 14
What paint remover worked better than what you had at the Can Opener?
bjond is offline   Reply With Quote
Old 01-13-2007, 07:18 PM   #7
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
It's called My Dad's, from a Bejaman Moore store $33 a gallon. I think the gallon will finish it.
The two types I tried at Topsail were terrible now that I see what this can do.
This metalwax really works well, the trick is the right paint remover to get every speck of the clear off if you miss a spot it looks bad, then redo the spot with remover, re-wax.
The My Dads stuff I have now is taking it off in one pass, so the front and street side are stripped completly 2 hours.
About 20% is polished.
Tomorrow we'll stip the other side in say 2, 3 hours at most.
The problem is the top part where the clear was worn away it is pitted and takes time to get shiny.
On the pitted part I was thinking about using white auto compound to cut a little away or 2000 grit wet sand paper, what do you think about that Herb?
The Metalwax takes about 7-8 minutes for two sq feet. I can see myself in it.
All I do is wipe on a cleaner, then a small amount of wax buff away.
Old 01-13-2007, 07:21 PM   #8
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Hey
Is there any way that you could take some pictures for us all to see.I would really like to get a look at what you have done.A before and after would be great for the photo books.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 01-13-2007, 07:37 PM   #9
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
I took pic's, this Verizon hookup leaves a little to be desired, I recieve e-mails fine but can't send out except thu my regular provider.
When I try to upload them it justs sits there, I miss my T1 connection.
I am wondering if trying to transmit from inside the tin can has anything to do with it
At worst I'll have it uploaded next week, also have a few pics from the rally.
Old 01-13-2007, 07:42 PM   #10
Devoman's Avatar
When you do get a chance.
Post them when you do get a chance to please.I am really intrested to see it polished some since I have seen it at the rally when it was unpolished.I bet it looks really nice.
Old 01-13-2007, 08:20 PM   #11
Images: 14
Auto compound works as does sanding. Sanding will put scatches worse than compound and will take longer to bring up to a reflective shine. You can use Mother Aluminum polish(Auto Zone) or Never Dull (Hardware store) also.
Are you using a polisher or polishing by hand?
Old 01-13-2007, 08:38 PM   #12
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Is white Dupont auto compound about equivalent to about 4000 or 5000 grit? I would have have thought that fine grit scratches would buff out?
I have a 7" 3000 Rpm buffer.
I need to sand or compound where the two sets of old numbers were they are a real problem.
Old 01-14-2007, 07:35 AM   #13
raptorron's Avatar
Kennesaw , Georgia
Bob,
I would be very carefull with the paper. If you use it on your numbers just do it by hand with circular motion,with minimum pressure, and keep it flushed with water (squirt bottle works well). Be sure you use a good pad with your polishing compound. It is as important as the polish. I normally use "3M Super duty compound" with " 3M wool pad". I agree with "jbond" , I use "Mothers Aluminum polish" for final step.
Never poilshed an air Airstream , but used this process on many sets of aluminum wheels.
I would also love to see pictures.
..........ron
Ron & Cindi
Air # 13727
Old 01-14-2007, 07:45 AM   #14
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I agree, posting pictures is a must.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Report: Southern Shine worked! rluhr Cleaning, Stripping & Polishing 137 05-23-2012 01:42 PM
Free Internet while "On-the-Road" driftwood On The Road... 45 03-25-2007 06:52 PM
Interest in a Woman's Rally wheel interested Forum Rallies & Meet Ups 394 01-14-2007 09:18 AM
Mammoth Lakes - New Shady Rest Campgroun (or Trial and tribulations) Safari-Rick On The Road... 5 08-11-2005 09:05 AM
Our first trip! Pls recommend dry run camp and other info... sarmimi On The Road... 30 04-11-2005 06:02 PM
