Old 01-14-2007, 07:51 AM   #15
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Actually my ISP will not allow you to send out email through them unless you authenticate. One of there ways to stop spamming. They use a special address smtpauth for sending outbound when not on thier network.
Michelle TAC MT-0
Sarah, Snowball
Old 01-14-2007, 03:37 PM   #16
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Originally Posted by raptorron
Bob,
I would be very carefull with the paper. If you use it on your numbers just do it by hand with circular motion,with minimum pressure, and keep it flushed with water (squirt bottle works well). Be sure you use a good pad with your polishing compound. It is as important as the polish. I normally use "3M Super duty compound" with " 3M wool pad". I agree with "jbond" , I use "Mothers Aluminum polish" for final step.
Never poilshed an air Airstream , but used this process on many sets of aluminum wheels.
I would also love to see pictures.
..........ron
Ron, I didn't need the sandpaper, I tried some red auto compound by hand, did nothing.
Then smeared it on and used a buffer at 2200 rpm, took a while but numbers are history.
Then I tried a section of the oxadized upper part with the compound worked like a charm, it now blends in with the stripped clear coat section below.
As of now all the clear coat is off, part of the ozadized areas are polished with all the experimenting with what to use I wore out the polishing pads on my buffer.
I'll get a few more tomorrow.
It's a fair amount of work but it really is looking good, I spent so far maybe 20 hours.
'77 Sovereign Intl 31' CB
Old 01-14-2007, 05:23 PM   #17
raptorron's Avatar
2006 16' International CCD
Kennesaw , Georgia
Bob,
Glad to here of your success. Since they want to close this thread, why don't you start a thread on your repair, then we can all keep up with your repair and trip progress and can get further progress on the "magic beads".
be safe......ron
Ron & Cindi
Air # 13727
2006 Bambi Quicksilver
T/V 2007 Yukon Denali
raptorron is offline   Reply With Quote
Old 01-15-2007, 06:20 PM   #18
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Lipets polishing thread
This is a new thread split out of the 2007 Can Opener Rally thread.
www.nesa.org
Air No. 6427
Old 01-15-2007, 07:10 PM   #19
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Too much rain to do much here today, did hunt down some new wool buffing pads my first one was on it's last legs.
I'm going to spend some time on it tomorrow.
Old 01-24-2007, 08:16 PM   #20
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Stripping the clearcoat, paimted the bannana skins
Name:	paint bannana 1.jpg
ID:	31275   Click image for larger version
Name:	polish begin2.jpg
Name:	polish begin3.jpg
ID:	31277   Click image for larger version
Name:	remove clearcoat-paint bannana skins 4.jpg
Name:	polish clear5.jpg
Old 01-24-2007, 08:20 PM   #21
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
The problem where the clearcoat wore away a long time ago left the metal to ozadize, I used red rubbing compound on a awool buffing pad 1/2" thick pad, at 2200 rpm.
It came off in short order
Name:	polish compound ox.jpg
Old 01-24-2007, 08:22 PM   #22
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
old numbers be gone
Name:	polish numbers 1.jpg
ID:	31282   Click image for larger version
Name:	polish number2.jpg
Old 01-24-2007, 08:24 PM   #23
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
A little fine tuning and doing the corners with metalwax
Name:	polish detail.jpg
ID:	31284   Click image for larger version
Name:	polish corner.jpg
Name:	polish rear corner.jpg
Old 01-24-2007, 08:26 PM   #24
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
clear coat off at last!
Name:	polish clear off.jpg
Old 01-24-2007, 08:27 PM   #25
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
half way
Name:	polish half way.jpg
Old 01-24-2007, 08:28 PM   #26
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
It's looking awesome! Am I seeing that you're doing all this work amongst other campers?? Wow.. an audience!!
sequoiacoast is offline   Reply With Quote
Old 01-24-2007, 08:28 PM   #27
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Enough work
Name:	polish enough.jpg
Old 01-24-2007, 08:35 PM   #28
1968 24' Tradewind
Eureka , California
Okay, now that's just not fair... you are NOT in New York... Right??????
Report: Southern Shine worked! rluhr Cleaning, Stripping & Polishing 137 05-23-2012 01:42 PM
Free Internet while "On-the-Road" driftwood On The Road... 45 03-25-2007 06:52 PM
Interest in a Woman's Rally wheel interested Forum Rallies & Meet Ups 394 01-14-2007 09:18 AM
Mammoth Lakes - New Shady Rest Campgroun (or Trial and tribulations) Safari-Rick On The Road... 5 08-11-2005 09:05 AM
Our first trip! Pls recommend dry run camp and other info... sarmimi On The Road... 30 04-11-2005 06:02 PM
