Old 07-25-2010, 02:47 PM   #1
Myrtle Beach , South Carolina
Met-All for polishing?
I want to use Met-All polish to cut through 49 years worth of oxidation. Should I start with P-37 Prep polish (very coarse) and progress to C-20, the C-10, or start with C-20? Someone else has also suggested Met-All's G formula to start and then to finish with C-10 using the Cyclo polisher. If there is someone who has experience using Met-All, I'd really appreciate the advice. Thanks!
jmbsc is offline   Reply With Quote
Old 07-25-2010, 03:59 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I never used the first ones you mentioned...just the pink Met Al Gl. It is great! I used it by hand polishing and cleaned up with corn starch. There seems to be no real cut to it like coarse rubbing compound types...Nuvite F7 or Gravel in a bottle. If you get the really rough corrosion off the final polish is GREAT..
Old 07-25-2010, 08:59 PM   #3
Melody......Was your skin heavily oxidized when you used Met-All G and explain how you used the corn starch. I may be missing something I need to know. Thanks so much!
Polishing my 76 rollingbubel Cleaning, Stripping & Polishing 5 10-29-2009 10:21 PM
Polishing a 94 Craftsman Cleaning, Stripping & Polishing 4 08-18-2005 12:58 AM
Serious about polishing... Safari Tim Cleaning, Stripping & Polishing 2 08-31-2003 08:23 AM
Polishing Inland RV Center, In Cleaning, Stripping & Polishing 1 08-13-2003 05:25 PM
