Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 01-11-2003, 08:26 AM   #1
david h
Profile:
meguiars polish
hello,
i am new to airstreams and this board. i have bought a 2003 19' bambi and know i should wax it spring and fall. my question is this, has anyone used "meguiars clear coat" polish before? any comments on using this polish?
the meguiars is easy for me to get.
thanks,
david h
david h is offline   Reply With Quote
Old 01-11-2003, 11:57 AM   #2
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Welcome top our forums site!!
There are several threads here you can read about waxing and polishing-but as long as you are using a NON-ABRASIVE you should be fine. Meguirs Quick Detailer also works well to give a clean up to small areas. (try our search for polishing_)
I use Turtle wax liquid, and Armor all wash on mine, although i recently tried the new Rain-x wash and wax, which seemed to work well.How much actual wax it will put on the AS I don't really know.
Old 01-11-2003, 12:09 PM   #3
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
If I had purchased a brand new Airsteam with the original owner warranty, I would maintain the exterior using the exact method that was in the owners manual. This way if any problems occur with the exterior finish, the warranty would cover it.
Just my $.02
-BobbyW
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 01-11-2003, 01:42 PM   #4
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
I use Walbernize from AirstreamDreams.com. One quart will just do a 34' (but I had two just in case).
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
SS Polish for sale, regular price Stefrobrts The Vendor's Forum 0 09-10-2003 11:30 AM
Super Simple Polish Method Safari Tim Cleaning, Stripping & Polishing 8 08-08-2003 09:17 AM
Southern Shine Metal Polish... trailertrash Cleaning, Stripping & Polishing 89 07-31-2003 05:33 PM
Best Polish to restore Airstream ?? bgow 1969 Overlander 1 08-06-2002 11:23 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 08:15 AM
