Old 10-23-2004, 06:31 PM   #29
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I don't understand why you would do a complete polish job and after all that work put acid on - its beyond me. None of the vintage folks I know with great polish jobs have used acid.
Then again, each to his/her own. There are lots of folks out there professing to be professional polishers that want to make a quick buck - acid or no acid they charge 150 or so to polish a trailer - some take 10 hours to do the job - others take 100 hours.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 10-23-2004, 07:28 PM   #30
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
I dunno
Ken,
tHERE WERE PROBABLY 12-15 OF THE vINTAGE group of the WBCCI there. Matter of fact, they had an open house of 10 or so after the seminar. I have pics of the guy, but I swear, I do not remember his name. Yes, They spoke of the many, many hours to complete the job. Anyway, the fellow that did the first one spoke of how that after so many hours, he was so disappointed that, after following all the proper steps, using all the so called proper chemicals (polishes,etc.) that his trailer looked like all the others- it had a 'milkiness' to the finish. I have no idea where he came up with the idea to acid wash it, but he did, and then after the final buff, it looked like a doggone mirror! I saw it. It stood out among all the others.
I had an Avion cab-over camper one time, and after I was through with it, the man who bought it, kept me up on his restoration and he, too, spoke of the people dedicated to those things using an acid wash as they finished them. The guys around here, (I live south of Atlanta) use the acid wash at the truck stop to do their fuel tankers, and them polish them to where they will blind you.
Anyway, nuff of this subject for me- good luck on your project,
jerry
steelbird312 is offline   Reply With Quote
Old 10-23-2004, 07:49 PM   #31
Silver Bullet's Avatar
Don,
Just try wet sanding with 1200 grit paper and let it sit on the south side for the winter. What you are trying to do is "force" oxidation. It doesn't take much, breaking the surface should suffice.
Oscar
Silver Bullet is offline   Reply With Quote
Old 10-23-2004, 08:31 PM   #32
Images: 59
Thanks for all the suggestions and tips.
I think I will forgo the acid wash, based on some articles I read about oxygen concentration cell corrosion. Acid may be a good way to brighten aluminum, but where it gets into seams and under rivet heads I think the potential for delayed and hidden damage is something I want to avoid.
Here's some FAA paper on the topic. http://www.faa.gov/avr/afs/300/pdf/2f-ch6_1.pdf
Old 10-24-2004, 06:20 AM   #33
AND MAC TOO
Jalina's Avatar
Images: 36
Mark
Just read all the post on the acid wash. The pro's and con's would make me think on the way I would go. I work at a trailer mfg. company and last year I had Alum. forman get me some acid wash to use on our Kenworth tanks. He told me to reduce it down with water but not sure the percentage. Husband put it in a sprayer and I was there to rinse it off quickly. And rinsed and rinsed and rinsed again. If you are not sure that you want to do the acid wash I would for sure take it to a truck wash and have them do it for me. Hope it works out for you and I just Suggested the wash to you for the effect you are going for. Didn't mean to make a big deal out of it.
Jalina
Mac&Jalina
Jalina is offline   Reply With Quote
Old 10-24-2004, 07:37 AM   #34
Ken J's Avatar
Durango , Colorado
Images: 14
I've been doing the polishing thing for about seven years now - have looked and studied all the methods. It takes about 10 times as much work to get to 100% as it did to get to 80%. Airmark was the polish about six years ago - they polish the big Bowing jets, then we all switched to Rollite now the polish of choice seems to be Nuvite. I've used all three and I do find Nuvite to be the easiest. Rollite is still an excellent choice and Airmark is really designed for use with air tools - and takes a little more skill to use. I would not run my car through a truck wash, so I won't use a truck wash on my Airstream - I figure most trucks are toast after 5-6 years maybe ten max. Also the trucks I've seen use a much heavier gauge aluminum metal. My trailers are 29 and 46 years old and I plan to make them last at least as long as I'm around. Airplanes tend to stay in the air many many years and there are strict rules on how to keep them up in the air and products that are allowed to be used. For my money I'll go with the Airplane guidelines over the truck guidelines any day. I also will not us SS, Gords or mothers or any other polish that is not approved for aircraft.
If there is an easier way to polish in the hands of the average do-it-yourself polisher, I'm all ears, because it is very long tedious work - but to me it has to be a proven method over the long term.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 10-24-2004, 07:50 AM   #35
AND MAC TOO
Jalina's Avatar
Images: 36
Ken,
I don't think you are getting what he is trying to do. He wants it to look like the rest of the trailer. (OLD) Not polished. At the truck washes they do have high pressure that you would not use on a car. But the acid is not put on with high pressure.And as of the years trucks will last all depends on the owner. We own a 89 KW and it is still making us money. They are just like anything else if you take care of it it will take care of you. On the acid wash it was just a option I thought would help him. I might just be a woman but we do know how to think.
Jalina
Mac&Jalina
Old 10-24-2004, 08:06 AM   #36
Ken J's Avatar
Durango , Colorado
Images: 14
Jalina
I'm aware of what Don is trying to do - you can see my earlier suggestion - leave it under a tree for 40 years and it will be all the same color. I would not want to mess too much with trying to dull alclad - it may be permenant.
Don - what you could do is flip the panel over and use the back side - you could do all kinds of things to it, then when you get ready to polish, turn it over and viola its ready to go.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 10-24-2004, 09:45 AM   #37
CanoeStream's Avatar
St. Cloud , Minnesota
Jeez Louise Ken -- We've got all sorts of thinking going on here...
I'm not trying to be an arbitrator from the non-silver side of the community, but will offer some recall from previous threads (threads that I will not dredge up due to the job of putting back front belly pan and banana wrap waiting in my driveway). Don having alclad is an extra challenge and I'm not sure any answer that makes it match now will continue to match as the respective surfaces age at their own rates. 40 years is looking better all the time.
I do not doubt that a combination of acid with other finishing materials can produce a cleaned & shiny trailer. The past advice from these forums is that common issues of sealing and leakage shared by Airstreams and aircraft have brought the aircraft refinishing industry to avoid acid use. This is echoed in Ken J's & Silver Bullet's replies in the 1st half of Page 2 of this thread.
Acids will tend to react fully after a finite time and not have a lingering effect. They are not magical catalysts that activate every time our rigs get wet. For a certain period they will age sensitive parts at a faster rate. I might suggest the question is whether an acid wash will kick the aged sealing on vintage trailers to the point that we will see leaks here and there that didn't exist before. Of course the problem is the difficulty in recognizing that a small leak even exists. The only way of testing this is to disassemble the trailer -- and I suspect the aircraft industry goes this far much more than we have. Thus has come the advice from aircraft refinishers and Andy at InlandRV -- don't use acid washes on Airstreams.
5 meter Langford Nahanni
Old 10-24-2004, 08:57 PM   #38
AND MAC TOO
Jalina's Avatar
Images: 36
Acid wash
Don, Jalina's mechanic here, Mac, I have used acid at truck washes for the past 21 years and I am now still driving a 1988 Kenworth W900 that we have owned for 10 years.Iunderstand the fears of getting the acid behind the rivits and thus causing leaks and things. I use it when the tanks and wheels get so dirty and road grime and they just won't come clean. On some other trucks I have owned we have used it on the paint and all, no problems. If I have time in the next couple of days I will acid wash a piece of scrap two or three times at time lenghts and post the pics for y'all to see. I will also try to get the name of the acid and the dellution rate for you. I know the look you are gooing for and this will do it , but then there's the ribbit thing!
Good luck
Mac
Mac&Jalina
Old 10-25-2004, 09:03 AM   #39
Images: 59
Good luck
Mac
Thanks! Looking forward to your pictures.
Old 10-25-2004, 10:38 AM   #40
Ken J's Avatar
Durango , Colorado
Images: 14
I've never said it doesn't make things shiney - aren't tank trucks welded aluminum?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
How to make YOUR OWN Patio/Awning Enclosure escapeez Commercial Listings 8 08-17-2017 05:12 AM
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 40 05-16-2017 04:58 AM
Help me make a decision on the rear floor! Bryanhu Repairing/Replacing Floor &/or Frame 4 07-11-2003 07:24 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
