Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 04-02-2003, 12:12 AM   #1
TBKP's Overlander
Profile:
Just started Compound Polishing. What are these black spots?
I bought a Makita polisher with a wool bonnet. 600-3000 RPM's. I've been running at 1500-2100. I have the Nuvite polishes G-7, C and S. Started with G-7. I am getting a mirror finish that I am thrilled with, BUT I am getting these black smudge marks. I can wipe them off somewhat. Am I going to fast, or too much or little polish. I still haven't fully removed the white etchings. On the 3rd pass with the G-7 they are almost gone. Is that what I need to do? Or do I need to get the cut heavier than G-7. Or do I need to go down to the C and then the S. I am finding that I need a fair amount of polish to remove the etchings. The black smudges don't seem to be related to the amounts of polish, but maybe I'm wrong.
TBKP's Overlander is offline   Reply With Quote
Old 04-02-2003, 12:19 PM   #2
TBKP's Overlander
Profile:
Make that F-7 that I am using. Confused it with G-6, which maybe I need to use.
Old 04-02-2003, 12:49 PM   #3
64GT
64GT's Avatar
Profile:
Get some sweatshirt material, put it over the bonnet after you've polished to remove the remaining oxidation.
64GT is offline   Reply With Quote
Old 04-02-2003, 03:41 PM   #4
TBKP's Overlander
Profile:
With polish or dry. When you say bonnet . do you mean the makita or do you mean a cyclo polisher. Thanks for your help.
Old 04-03-2003, 07:36 AM   #5
64GT
64GT's Avatar
Profile:
You move the polish around with your polisher and bonnet - but the bonnet gets 'mucked' up with the black oxidation. So if you throw some sweatshirt material over the bonnet - you can use that to remove the remaining black muck. You don't use more polish on the sweatshirt material. Make sense? Don't worry before long, you'll be an expert.
Old 04-03-2003, 01:34 PM   #6
susan martin
Profile:
USE COMMON FLOUR TO REMOCE THE BLACK SMUDGES. JUST PUT SOME IN A SQUEEZE BOTTLE AND SQUIRT ON THE AREA OR RAG AND THE BLACK WIPES RIGHT OFF
just lookin for John Wayne
Martin and O'Brien
susan martin is offline   Reply With Quote
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 09:45 AM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 08:40 AM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 06:40 AM
Darned water spots! Charcigar Cleaning, Stripping & Polishing 6 07-30-2002 03:29 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 05:17 PM
