Old 10-26-2011, 12:46 PM   #1
1973 31' Sovereign
Kilgore , Texas
Unhappy Issues with an acid bath.. Fixing the blimishes caused?
I was stripping down this airstream sovereign. and I found an article about acid bathing in order to remove old build up. However some of the plastic has melted and around the trimming and has caused this black residue to build up around the trimming. Any suggestions?
dtodom is offline   Reply With Quote
Old 10-26-2011, 01:43 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Greetings, dtodom, and welcome to the forums.
I looked at your attempt to display content from Facebook, and it appears that the problem is with your picture on Facebook, not with your coding on Airforums.
Lynn
WBCCI 21043
Old 10-26-2011, 02:30 PM   #3
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
If you haven't already done so, you should use a solution of bicarbonate of soda and water to neutralize the acid bath. Some acid will be trapped beneath your trim and even under rivets. Unless neutralized it will continue to eat at those locations and can lead to leaks (the rivet holes will enlarge).
Forrest
Out for coffee!
Forrest is offline   Reply With Quote
Need help with Rear Bath falling out. Slowride66 Repairing/Replacing Floor &/or Frame 32 06-17-2012 05:10 PM
'73 TW Wet Bath Floor issues my3sonsdad Repairing/Replacing Floor &/or Frame 1 07-01-2011 12:40 PM
Relocate bath GaCamper Sinks, Showers & Toilets 4 05-14-2011 04:56 PM
Wet bath to shower? osolow Sinks, Showers & Toilets 6 03-24-2011 10:25 AM
Bath Sink w/gooseneck and shower stub source CtRobert Sinks, Showers & Toilets 0 03-04-2011 08:04 AM
