Old 04-13-2011, 09:55 AM   #1
JuliaPowell's Avatar
1966 26' Overlander
Melksham , Wiltshire
Is this a classic case off filform
We have finally started on the task of polishing, using Nuvite on our 66 Overlander, the door has lots of black speckles, is this a classic case off fillform?
We have been told we can remove this using a 500 grit sanding disc on the polisher followed by 1000 grit and 2000 grit with lubricant oil sprayed first to the door, and then finished off with Nuvite F7, C and S.
What do you think?
What do people think about going over the whole AS with 1000 / 2000 grit before using the Nuvite polish? As this would seem a much quicker process if the trailer has heavy oxidation?
Also we have cloudy patches, does just mean I did to make more passes with the Nuvite F7?
One last question, why is the flag on the street side appear to be back to front? (see the attached photo’s) at first I thought the POV must have removed this and put it on wrong, but checking other photos online this seems to be how they left the factory, why ?
ID:	126891   Click image for larger version
JuliaPowell is offline   Reply With Quote
Old 04-13-2011, 11:25 AM   #2
2008 16' Safari
Destrehan , Louisiana
No, that's pitting. Likely causes are road salt, salt spay or acid.
dlb435 is offline   Reply With Quote
1984 270 Classic Coloradobus Classic Motorhomes 6 04-24-2012 11:47 AM
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
Buying a classic jaxenro Classic Motorhomes 15 06-17-2011 09:39 PM
Classic Airstream Motor Home T-shirt and gift items maltnhops Classic Motorhomes 0 03-18-2011 11:10 PM
31' Classic weight question pappy19 Tow Vehicles 11 02-06-2011 09:55 AM
