Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 10-17-2013, 06:57 PM   #1
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
In order of importance.... what happens first?
Getting ready to start the process of putting in our new floor in the rear. I know that I need to address all leaks & seams & windows before putting that new floor in. If I work on sealing the seams, rivets, windows, vents, etc....won't all that work be undone when polishing occurs down the road???
My first order of business is remove all the crappy sealant that someone applied and then painted with metallic paint. Once that occurs, I will seal it all up again. I have to get my windows in tip top shape as well.
But from what I've read, you seal all such things after polishing. Am I wrong?
Airstreamin' dreamin'.
Follow our blog! https://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 10-18-2013, 02:05 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
We actually removed the old caulking, polished the seams then sealed them long before we polished the whole trailer. Check out this thread for our reasoning and various other thoughts on the order things are done.
Good luck in whatever you decide to do ~
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 10-18-2013, 02:55 PM   #3
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
I have treated the floor with thompsons water seal next shell back on then polish seal and then recaulk! Of course the belly pan after the floor before shell on.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 10-18-2013, 03:04 PM   #4
InsideOut's Avatar
1956 22' Safari
Images: 108
Lightbulb
My concern with coating the plywood with a sealer is the compatability with any glues you may use for your floorcovering. A lot of floorcovering glues need to penetrate the wood to stick...especially with the extreme heat our trailers are subjected to.
Also, by the time you attach the sill/shell back to the frame, screwing/bolting through the plywood, you breached the sealer anyways. Personally, I think it is not necessary...but I know others disagree.
Shari
Old 10-18-2013, 08:40 PM   #5
1966 17' Caravel
All of the bolt holes will be sealed but I know what you are talking about I have not figured out yet what type of flooring that she wants. My thought was I wanted to make the floor water resistant but still wanted it to breath so that in case it did get wet it could dry. Have to finish covering all of the holes for the stripping and cleanup.
Cliff
Just about to order 2012 30' Flying Cloud - What have I forgotten? Hibby Buyer Guidelines 36 02-24-2012 05:56 PM
Interior Panel order kitter General Interior Topics 5 01-29-2012 05:22 PM
Order of Events advice GreyMattr General Repair Forum 6 11-11-2011 10:53 AM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
Importance of being in shape and AS restoration Lothlorian Off Topic Forum 3 08-18-2011 10:29 AM
