Old 02-11-2016, 05:50 PM   #1
1976 25' Tradewind
Sulphur , Louisiana
I can't get rid of these water stains.
Name:	ImageUploadedByAirstream Forums1455238086.874363.jpg
ID:	257157 looks like water stains from draining condensation from the air conditioner. This is about 4 passes with nuvite coarse. Can't remember what number nuvite. These streaks will not go away.
Bobkatbry is offline   Reply With Quote
Old 02-19-2016, 11:18 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Have you stripped the clear coat off the trailer before you tried polishing? Looks like possibly not...hard to tell.
Shari
Old 02-20-2016, 06:13 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Sorry to break the news....these streaks will require compounding.
Old 02-24-2016, 05:43 PM   #4
1976 25' Tradewind
Sulphur , Louisiana
What is compounding? Nuvite coarse thru fine?
Old 02-29-2016, 10:05 AM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
Compounding is separate from Cyclo-Polishing...check this webpage out. It uses a more aggressive approach with different pads & tools. The process actually puts some scratches on the skins that are then removed with the Cyco-polisher. There are many different ways to approach compounding - we've used both Nuvite w/horizontal wool pads and Tripoli-type bars w/vertical cotton buffs with good success. There are lots of "polishing threads" that can help you decide which method will work best for you...
Below is a YouTube video of Mr. InsideOut "compounding" using the bar method (then Cyclo-Polishing) at the RMVAC Rally several years ago.
Shari
Stains on curtains and grease stains wallpaper near upper cookstove oxblood Upholstery, Blinds, Walls & Interior Finishes 0 04-07-2015 06:52 PM
How to get rid of crystals in hot water heater? H. Huester Water Heaters, Filters & Pumps 5 06-11-2010 08:29 AM
Can't get rid of Cloudy alu on a 1961 Safari mscott Cleaning, Stripping & Polishing 5 07-13-2007 10:02 PM
Standing Water!How to get rid of it? Chitown AirStreamers Plumbing - Systems & Fixtures 16 07-28-2003 01:05 PM
Should I get rid of my appliances? Mr Jody Hudson General Appliance Topics 21 07-21-2002 08:27 PM
