Old 08-21-2012, 05:01 PM   #1
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
How to remove vulkem...
We've finally got to the point where we are starting to polish our Safari... so I pulled off the name tags , the rear lights and the side markers. Someone had replaced several of these pieces and used 'a generous' amount of vulkem to seal them. I have not been able to remove most of it, at least not w/o scratching the finish very badly. Is there a good chemical or process for cleaning these areas up before we get to that area? Oh yea it's overly done on the seams and esp. the front rock guard. Thanks...
Barry & Karen
goshawks00 is offline   Reply With Quote
Old 10-15-2012, 09:22 AM   #2
zonacpa's Avatar
Tucson , Arizona
I have found there is only one chemical that can get old, hardened vulcum off and that is the goof off PRO. Don't get the lesser goof off. It won't touch hardened vulcum. I made the armature mistake of taking my 3" angle grinder with a wire wheel to the vulcum bead on the old AC unit on the roof. Well, the wire wheel did take the vulcum off in short order. However it SPRAYED the vulcum all over the rest of my trailer. So instead of having hardened vulcum on the roof, I now had little spots of hardened vulcum literally all over the trailer. That was a lot of work to clean up. I tried alcohol, alcohol and bar keepers best friend, gasoline, paint stripper, paint thinner, cussing, getting drunk and cussing, and finally the only thing that worked was goof off pro combined with bar keeps. I poured the goof off pro on an area, then a dash of bar keeps, then went at it with a course wool pad on my 7" variable speed angle grinder. It will leave swirl marks! But if you are going to compound the trailer then no problem.
zonacpa is offline   Reply With Quote
Old 10-15-2012, 09:24 AM   #3
Ottawa , ON
A heat gun can also get results with Vulkem. They aren't expensive these days, either. Just be sure to use a super-heavy-duty extension cord, they suck a lot of juice!
Try plastic scrapers to avoid marring the finish.
Old 10-15-2012, 10:41 AM   #4
1981 31' Excella II
New Market , Alabama
I think I used Kleen Cutter Gel Formula and that worked.
Perry
Old 10-15-2012, 12:41 PM   #5
Baltimore , Maryland
MEK. Where gloves and a respirator. MEK is at the top of the solvent chain.
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
Why Vulkem perryg114 Ribs, Skins & Rivets 32 09-13-2011 07:10 AM
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 08:26 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 07:40 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 07:57 PM
