Old 06-05-2011, 11:50 PM   #1
Astriking's Avatar
1979 31' Excella 500
San Bernardino , California
How to remove swirls?anyone can tell me what is the best technique for removing the m
anyone can tell me what is the best technique for removing the marks (swirls) on the aluminum after being polished. I have used different methods but I have not been able to achieve remove the marks. The marks can only be viewed closely by far can not be seen. The work is still not satisfactory for me, because I've seen other AS almost perfectly polished. Viewing from the bottom up are black marks. Here are some pictures of the materials currently used have already.The firs pic show some spots no very shine.
ID:	131695   Click image for larger version
ID:	131697   Click image for larger version
Javier
Astriking is offline   Reply With Quote
Old 06-06-2011, 12:02 AM   #2
Seymour's Avatar
1980 24' Caravelle
Prince George , British Columbia
Images: 13
have you read the miscellaneous literature at perfectpolish.com? they seem to be doing alright.
I'm trying to polish our trailer right now as well. I think that the corrosion is pretty bad though, as it seems to be taking quite a few passes to get all the filiform and cloudy spots out.
But hey, whatever. I'm starting to enjoy it.
John
Seymour is offline   Reply With Quote
Old 06-06-2011, 12:02 AM   #3
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Well by looking at your collection you certainly have everything under control...or should I say - under the sun!
Seems like you eventually will come up with the right formula. but you might try kerosene for picking up the black as it stays wetter longer and allows you to work more steadily with the polishing itself out detail. Sometimes the swirl marks just disappear.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 06-06-2011, 12:09 AM   #4
Astriking's Avatar
Yes I've already read the technique described in at perfect polish.com.And I did several passes with different
rougue bars, but no luck yet.
Javier
Old 06-06-2011, 12:13 AM   #5
Astriking's Avatar
where I can buy kerosene in california?
and after use kerosene what should I do?
Javier
Old 06-06-2011, 12:52 AM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The only way I know to remove swirl marks is to use a random orbit machine such as a Cyclo. Cyclo has two heads. Porter Cable makes a single head machine.
I use a Cyclo.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 06-06-2011, 01:01 AM   #7
Astriking's Avatar
I already use cyclo machine with all Nuvite grades,
and still I can see black clouds.
Javier
Old 06-06-2011, 08:16 AM   #8
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Astriking
After compounding w/Nuvite 7 (many passes), to remove swirls I first used Nuvite 7 again w/Cyclo (sometimes 2 to 3 passes) then used Nuvite S w/cyclo. I did have a few areas w/clouds and the only way I got them out was to recompound w/N7. Then re-cyclo with N7 and S. I used mineral spirits to clean surface when compounding and then went to corn starch for cyclo work. Lots of work! When done I found it worth the work as it is still turning heads over a year later. Good luck with yours.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 06-06-2011, 08:52 AM   #9
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Astriking
One more thing - I found my best success when I used the soft cotton sweatshirt material from Perfect Polish on my cyclo. I also changed over to a clean spot on the cotton often.
Tim
TAC MI 14
Old 06-06-2011, 01:19 PM   #10
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We use mineral spirits (instead of kerosene) to remove compound before switching to the next finer grade. The Cyclo w/"S" & microfiber cloth is the key to a mirror shine IMO. Also, be sure your pads/buffs are clean - we "rake" them every couple of passes and wash them in TSP at the end of each day's work.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 06-06-2011, 02:03 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Be sure that when you compound, you lighten up toward the end to remove as much swirl as you can. This will make it much easier to get the final finish you want.
Also, I compound with "C". It is not as aggressive as "F". and does not leave the heavy swirls.
The compounding pass is the most important pass in the process.
Then I Cyclo with "F", then with "S". I always use new fleece material with "S", never used and washed. Used and washed is OK for "F", but not "S".
Clean the surface between applications, and use the "S" very sparingly.
Clouds are usually caused by a previous pass not being done enough, most likely the compounding pass.
Old 06-11-2011, 12:39 AM   #12
84Sovereign's Avatar
1984 27' Sovereign
Escondido , California
We just did re-polish on ours. One trick I discovered was to challenge myself as to how little Nuvite S I could use with the Cyclo. I used the microfiber Cyclo pads, changing them out for clean ones very frequently. Seriously, you don't need very much S. Try just a few fingerprints of the S in a 2' x 2' area.
84Sovereign is offline   Reply With Quote
Old 06-11-2011, 06:17 AM   #13
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Corn starch, sprinkle on, lite buff, gone.
'77 Sovereign Intl 31' CB
Old 06-11-2011, 06:59 AM   #14
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Or
or I hear flour might do it as well.... don't hold me accountable... if it doesn't work, blame it on LI Pets
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 08-05-2011, 01:31 PM   #15
Jcashcollect's Avatar
1978 31' Excella 500
Kelowna , British Columbia
looks like a duo head cyclo is the only way to remove swirls. Can't shake the swirls with a 7" polisher, no matter what I use.
Jcashcollect is offline   Reply With Quote
Old 08-05-2011, 01:52 PM   #16
Looks like a duo head cyclo is no where to be found to buy or rent where I live. So I'm going to try my 7" polisher with a foam pad. Any thoughts/help would be appreciated. This airstream restore would have been so much easier if i lived in the US.
Old 08-05-2011, 02:03 PM   #17
x
XXXX , XXXX
Jcashcollect. Here is a list of CDN dealers out west.
Diversified Distributors / Farmworld
132-250 Shawville Blvd Se
Suite 230
Calgary, AB
Canada
800 497 1782
Robinson Pump West Ltd
3542 78th Avenue NW
Edmonton, AB
Canada
780-461-0828
Pro Detail Supply Inc
Bay 120, 6 Renault Crescent
St. Albert, AB T8N 1E1
Canada
780 458-5373
bruce@prodetail.ca
Auto Magic of Vancouver
#6-7315 Meadow Avenue
Burnaby, BC
Canada
604-951-8848
Auto Magic of Manitoba
1145 Keewatin Street
Winnipeg, MB
Canada
204-697-5874
wasagachris is offline   Reply With Quote
Old 08-08-2011, 09:07 PM   #18
Sorry, I should have specified that I'm in Saskatchewan. Thanks for the links. I would love to rent to see if it would work first. Here is a photo of the side that I have used medium grit and fine grit with a wool pad, and Maguires Swirl Remover with a foam pad on a 7" variable speed polisher. Is there any way to remove these without a cyclo? It looks great when the Sun isn't blasting on it. It am still hoping there is a non cyclo solution.
Any help would be appreciated. It's been a couple weeks of frustration.
TIA
Old 10-21-2019, 01:23 PM   #19
Swirls on new AS
How much of it is normal? Had my Bambi for 2 months. Brand new. Dropped it off at the dealer this AM to address issues and it was under the sun like I had never seen it before. Noticed swirls when close and at certain angles. Had not noticed that when camping. Of course, we’re often camping in the woods so these would not show without full sun light. Did mention to the dealer and they said they could Walbernize it for me and that it would address the issue. Good answer? How much if it is normal? I’ve not washed it yet so it can’t that. Either factory or dealer prep induced. Any info appreciated.
steilkurve is offline   Reply With Quote
Old 10-21-2019, 01:38 PM   #20
2019 22' Sport
High River , Alberta
Originally Posted by steilkurve View Post
How much of it is normal? Had my Bambi for 2 months. Brand new. Dropped it off at the dealer this AM to address issues and it was under the sun like I had never seen it before. Noticed swirls when close and at certain angles. Had not noticed that when camping. Of course, were often camping in the woods so these would not show without full sun light. Did mention to the dealer and they said they could Walbernize it for me and that it would address the issue. Good answer? How much if it is normal? Ive not washed it yet so it cant that. Either factory or dealer prep induced. Any info appreciated.
Its the best thing to do at this point.
How much will they charge to Walbernize?
If you buy it yourself, make sure you get the Super Seal. The Cleaner Polish & Glaze is for older trailers. My dealer sold me the wrong stuff and it seemed to introduce swirl marks.
AlbertF is offline   Reply With Quote
Aargh- how do I remove this cabinet?? NoMoSOBs Interior Restoration Forum 3 06-06-2011 08:45 PM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 11:15 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 08:40 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 08:57 PM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 02:03 PM
