Old 08-05-2011, 12:31 PM   #15
Jcashcollect's Avatar
1978 31' Excella 500
Kelowna , British Columbia
looks like a duo head cyclo is the only way to remove swirls. Can't shake the swirls with a 7" polisher, no matter what I use.
Jcashcollect is offline   Reply With Quote
Old 08-05-2011, 12:52 PM   #16
Looks like a duo head cyclo is no where to be found to buy or rent where I live. So I'm going to try my 7" polisher with a foam pad. Any thoughts/help would be appreciated. This airstream restore would have been so much easier if i lived in the US.
Old 08-05-2011, 01:03 PM   #17
x
XXXX , XXXX
Jcashcollect. Here is a list of CDN dealers out west.
Diversified Distributors / Farmworld
132-250 Shawville Blvd Se
Suite 230
Calgary, AB
Canada
800 497 1782
Robinson Pump West Ltd
3542 78th Avenue NW
Edmonton, AB
Canada
780-461-0828
Pro Detail Supply Inc
Bay 120, 6 Renault Crescent
St. Albert, AB T8N 1E1
Canada
780 458-5373
bruce@prodetail.ca
Auto Magic of Vancouver
#6-7315 Meadow Avenue
Burnaby, BC
Canada
604-951-8848
Auto Magic of Manitoba
1145 Keewatin Street
Winnipeg, MB
Canada
204-697-5874
wasagachris is offline   Reply With Quote
Old 08-08-2011, 08:07 PM   #18
Sorry, I should have specified that I'm in Saskatchewan. Thanks for the links. I would love to rent to see if it would work first. Here is a photo of the side that I have used medium grit and fine grit with a wool pad, and Maguires Swirl Remover with a foam pad on a 7" variable speed polisher. Is there any way to remove these without a cyclo? It looks great when the Sun isn't blasting on it. It am still hoping there is a non cyclo solution.
Any help would be appreciated. It's been a couple weeks of frustration.
TIA
Aargh- how do I remove this cabinet?? NoMoSOBs Interior Restoration Forum 3 06-06-2011 07:45 PM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 10:15 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 07:40 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 07:57 PM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
