Old 10-09-2016, 01:22 PM   #1
1971 29' Ambassador
New Berlin , Wisconsin
How to get Mirror Shine
Hello, I am attempting to restore a 1971 Airstream. I am wondering how to get that shining mirror like finish I see in alot of pictures. I am planning on getting stripper to get the clear coat off. I wasn't sure at first if it had clear coat but I see splotching near the roof and from what I've read that is a good indication.
Then I am planning on using muriatic acid and mineral spirits to get rid of any oxidization
Lastly I bought Flitz to polish.
berlin is offline   Reply With Quote
Old 10-09-2016, 01:26 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, strip to bare metal and polish with finer and finer polish until you are satisfied. You might want to reconsider using the acid. There are dozens of videos on YouTube for reference and many threads here.
Old 10-09-2016, 01:48 PM   #3
1971 29' Ambassador
What do you mean by finer and finer polish.
Do you mean the pads that I use to polish it or the polish that I buy?
Old 10-09-2016, 02:32 PM   #4
Southwestern , Ohio
Welcome to the forums!
My first suggestion would be, DON'T USE ACID on your Airstream! I can't speak from personal experience but the conventional wisdom is that you can never neutralize the acid that gets into the seams and under rivet heads which will lead to leaks "down the road".
There is a large folklore on polishing Airstreams and several companies that sell the supplies. Here's one that has a lot of information on their web site-
One of the more popular polishing systems is Nuvite. This involves a succession of abrasives. You start by polishing off the oxidation with Nuvite F-7 or F-9 grades using a rotary polisher and then go to one or more finer grades (C & S) using a random orbital (Cyclo) polisher.
I used Nuvite to polish our first Airstream. I could afford to have a professional polish our current Airstream!
Some other polishes are recommended by others. I believe one professional aluminum polisher uses Mothers Aluminum Polish
Our present trailer was polished by Mike Rice of Time Tested Restorations and he did a fine job.
He uses Gord's Aluminum Polish.
Good luck with your project, and as always--"your mileage may vary".
Nuvite-F is offline   Reply With Quote
Old 10-09-2016, 08:25 PM   #5
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Berlin,
After I stripped the little clear coat that remained, I polished with Nuvite C and then S grades. Used a 7 inch buffer with the C grade and the random orbit to final polish the S grade. No acid!
Wear a hazmat suit and some goggles.
Beaker63 is offline   Reply With Quote
Old 10-10-2016, 01:54 PM   #6
Neophyte's Avatar
1967 24' Tradewind
Aurora , Colorado
Listen to Nuvite - F.
Neophyte is offline   Reply With Quote
Mirror / Mirror what type of Mirror? Jeep GC dlkershaw Towing, Tow Vehicles & Hitches 9 12-10-2015 03:14 PM
Shine Chummy Shine, Exterior Done! Chaplain Kent Classic Motorhomes 3 06-06-2013 04:01 PM
Need A SHINE?? Meet the Shine King!!! Chitown AirStreamers Commercial Listings 72 08-01-2012 11:18 AM
Would you give up some mirror shine if..... Becky B. Cleaning, Stripping & Polishing 17 08-25-2009 06:11 AM
Mirror Mirror on the wall.... GT1963 The Pet Forum 9 03-15-2004 08:42 AM
