Old 08-03-2011, 06:56 PM   #1
1989 29' Excella
Tyrone , Georgia
How to attain a uniform dull finish.
I was playing around with a gray scotchbrite pad and my orbital sander attempting to achieve a slightly dull brushed finish. The finish had the right amount of light reflection for us but the problem seemed to be uniformity. Any suggestions on getting it to look consistent?
mikeandnora is offline   Reply With Quote
Old 08-03-2011, 07:25 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
1) Polish it to a mirror shine, then wait about 10 years.
2) Replace all the panels with "mill finish" aluminum.
3) Walnut shell blasting...leaves a nice matte finish - but not "brushed".
Shari
Old 08-03-2011, 07:37 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
I was raised in the spec home business . . . I always think of resale. If I disregard resale, I always think "reversible". If it's not resalable and reversible, I don't do it. My .02
Old 08-03-2011, 07:52 PM   #4
toastie's Avatar
1955 22' Safari
Great Lake State , .
Try Liberon Steel Wool 0000 with turttle wax or nuvite S with a good backing block, going to try it on my 1955 Safari. Liberon the highest quality steel yields long running fibers that allow for an even, consistent scratch pattern. The steel wool has been stripped of almost all oils for a low residue finish. Crumble resistant.
Liberon Steel Wool - Rockler Woodworking Tools
toastie
toastie is offline   Reply With Quote
Old 08-03-2011, 08:02 PM   #5
1989 29' Excella
Tyrone , Georgia
The grey scotchbrite pad I was using brings aluminum closer to a polish than the original mill. I think it could just go through a series of lesser abrasives to move towards a mirror (89 mirror anyway). Thoughts?
Old 08-03-2011, 08:08 PM   #6
1989 29' Excella
Tyrone , Georgia
toastie
What do you mean by backing block? How about using it with the random orbital? The dewalt I have has loop fasteners that did a good job of holding on to the scotchbrite pad at least.
Old 08-03-2011, 08:11 PM   #7
toastie's Avatar
1955 22' Safari
Preppin
Old 08-03-2011, 08:58 PM   #8
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
I've heard that using a Cyclo with wool fabric, like an old US Army issue wool blanket, does the trick. No first hand experience, however.
Traveling With Elvis
life with a 1956 Sovereign of the Road
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Old 08-04-2011, 05:45 AM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you want a bunch of swirls, use the random orbital. No Airstream ever built has swirls in the metal, it should have a "grain" in one direction only. A buffer or cyclo polisher will give "swirls", but they will be so small as to be invisible.
I did use Scotchbrite pads on an Airstream to try to remove the worst of the marks where some joker sanded it. I used a back-and-forth motion to try to emulate the mill finish found on them. While it was a vast improvement over what was there, I can't recommend the end look as an ultimate goal.
Old 08-04-2011, 05:49 AM   #10
safari62's Avatar
1962 22' Safari
1957 22' Custom
Vacationland , Maine
Images: 43
satin finish
http://www.airforums.com/forums/f441...ish-72209.html
safari62 is offline   Reply With Quote
Trident System Exterior Finish Woosch Cleaning, Stripping & Polishing 13 08-19-2017 11:06 AM
matching aluminum... finish color choices funkill Upholstery, Blinds, Walls & Interior Finishes 1 06-13-2011 03:06 PM
ReJex Polymer finish nm1oqrz Cleaning, Stripping & Polishing 3 06-08-2011 03:19 PM
Porter Cable 7424 for finish polishing. Need suggestions. Pads, polish, etc. ST131 Cleaning, Stripping & Polishing 0 04-02-2011 11:30 PM
Should I wait to finish trailer b4 ordering axles 386kustoms Axles 2 03-06-2011 11:42 AM
