Old 09-03-2004, 12:41 PM   #1
JohnG's Avatar
How Do You Polish Around Letters?
This is probably a dumb question. I figure that you have to do it by hand, but can you still achieve the mirror finish by hand. I don't want to have to pull the letters off so what's the trick?
Also what about polishing around window frames and the nameplate and other items on the trailer, are these all done by hand?
Just adding my 2Ę worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 09-03-2004, 01:02 PM   #2
Images: 14
I took my Globetrotter letters off by cutting a hole in the inner skin and removing the spring clips on the pegs of the letters.
I use a block of hard form (packing material) to hand polish around windows, the door etc where the buffer won't work. I have been disappointed with just polishing by hand as the result leaves finger swirls. Use sweatshirt or microfiber cloth over the foam to polish with. Cotton towels will leave scratches.
bjond is offline   Reply With Quote
Old 09-03-2004, 04:28 PM   #3
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
How did you patch those holes?
Rog
May you camp where wind wonít hit you, where snakes wonít bite and bears wonít git you.
Rog0525 is offline   Reply With Quote
Old 09-05-2004, 09:03 AM   #4
JohnG's Avatar
I really don't want to remove the letters. I would much prefer just going with the exta sweat and working slowly around the letters. Will this block method work in such tight areas as the letters?
John G
Old 09-05-2004, 09:25 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Dremel with a polishing wheel?
Aaron
WBCCI #XXXX AIR #2495
Old 09-05-2004, 09:44 AM   #6
JohnG's Avatar
Aaron
I tried a Dremel but it didn't seem to work very well either. I don't think you can apply enough pressure to get a good result with such a small and lightweight tool. I'm only in the first stage of polishing the nose area right now. I'm using the first step of the Rolite system. I want to get this area polished up and then repaint the letters before I install the rock guard over the front windows.
Finishing the trailer off to a mirror shine will make the letter areas on the front and back look really bad if they can't come out to a good shine also, but I don't expect the high quality shine that will surrond them.
I though of cutting them off and doing the work, but I'm not sure I like the idea of riveting them back on and not sure I could get them straight again.
John G
Old 12-29-2013, 06:18 PM   #7
Mflanery's Avatar
1972 23' Safari
Tyler , Texas
Did you ever solve this problem
Mflanery is offline   Reply With Quote
Old 01-08-2014, 03:27 PM   #8
outofcontrol's Avatar
1996 28' Excella
Portland , Oregon
Not sure if you noticed, but this post was from 9+ years ago.
FWIW: I removed my letters to polish under them. I figured that I'm spending 200+ hours to polish, what's another 15 min?
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
outofcontrol is offline   Reply With Quote
Gords Polish will work for you! GordsPolish Commercial Listings 29 04-29-2005 09:34 AM
SS Polish for sale, regular price Stefrobrts Commercial Listings 0 09-10-2003 10:30 AM
Southern Shine Metal Polish... trailertrash Cleaning, Stripping & Polishing 89 07-31-2003 04:33 PM
Looking for letters FrankR Our Community 6 10-14-2002 06:16 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
