03-08-2016, 08:41 AM
#29
1970 25' Tradewind
anderson
, South carolina
Getting on top of your airstream
Originally Posted by Bob Cooke
I've been on top of my 1970 25 ft my a couple of times to polish and paint the
Center section. You may have on hand 1@1/2 or 2 in. Wide x3/4 thick strips or
Purchase at builders supply cheap. Cut about 20 or 25 pieces and lay them out in
A row on concrete or long table with about 1in. Between them. Take 1 in. Wide
Nylon strap from tie down sets and nail or staple to the ends of the strips. On the
Last slat leave about 10 or 15 feet of strap free. Throw the loose straps over the
Trailer and tie off to awning arm or anything else available to tie to. Now you
Have a 2 or 3 ft. Wide lattace fitting the rounded contour of the air stream. Adjust
Free straps for top center - rounded edge etc. When not in use roll the lattace up
Like rolling up roofing paper and easy to store. This method you can lean stand
Or crawl full weight and no damage. Also sed this method to install ac unit on top
Of my c-10 avion truck camper. Try it out. Worked well for me. Bob Cooke
Michael - vision rolling out a,2x10 carpet runner. Get on an 8ft ladder and go
Up to the top step lay the carpet over the trailer end for end. Remember the
Unit I made is wood slats. Step off the ladder on onto slats. Can't make a picture
Just now so hoe this helps you understand. Have a nice day. Bob Cooke
03-08-2016, 09:05 AM
#30
2016 25' Flying Cloud
Jupiter
I think I have it pictured, but if you are using it strap side down, how are you keeping the staples or nails from scratching the surface of the AS?
03-08-2016, 09:23 AM
#31
Holly Springs
, Mississippi
I believe BobC means strap side up. But I don't understand how/why the wood slats don't scratch the roof.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
06-10-2016, 12:37 PM
#32
2014 16' Sport
Dunedin
I use a mop with a large soft head. Worked very well.
06-10-2016, 01:08 PM
#33
1978 25' Tradewind
Metro Phoenix
I use a ladder padded with the old padded board that used to be the pull section under the gaucho. I put some screw eyes in the non-padded side of the board, and use cable ties to attach the board to the ladder. That makes it several feet long, and it hasn't scratched anything yet.
The padded board rests horizontally just under the awning. It's worked for the installation of two solar panels, a new TV antenna, a new radio antenna, and refurbishing the original airconditioner (including a vacuum pump and a 30# bottle of R-22).
06-10-2016, 01:43 PM
#34
2002 30' Classic S/O
Melbourne Beach
I use an extension ladder with foam padding made from a "pool noodle". Cut it in half and slit the halves lengthwise on one side. Slip them over the legs of the ladder where it leans on the trailer at the awning rail. Put it up high enough that you can hold on to it while you step to the roof. Walk only on the rivet lines running across the trailer. Those are the ribs. If you have to work elsewhere, use boards to bridge between the ribs. The roll up lattice sounds like a good idea. I may make one.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
06-10-2016, 02:39 PM
#35
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
When we need to work on or wash the roof the front loader on the backhoe works pretty well
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
06-11-2016, 06:35 AM
#36
1996 25' Excella
Tillsonburg
, Ontario
I've repaired my AC and replaced the old antenna with a new Winegard without having to climb on the roof. I put a padding on the awning cover and worked from the ext ladder.
JCW
06-11-2016, 04:04 PM
#37
Anna Maria
Al
I have been doing the very same.
How does it go ? Great minds.....
06-11-2016, 04:25 PM
#38
Biloxi
, Mississippi
Telescoping ladder with a couple of kayak roof pads. They are already pre cut perfectly to fit the ladder.
MICHAEL
08-11-2016, 11:20 PM
#39
1972 31' Sovereign
felton
I looked into this a while back and read that it's ok to walk on the roof ? Maybe I was mislead. ?
08-12-2016, 04:09 AM
#40
2013 30' Classic
Greenwood
, Mississippi
Maybe so, but I'm chicken.
Cluck, cluck, cluck...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
08-15-2016, 09:09 PM
#41
Vinton
, Louisiana
Originally Posted by Bobkatbry
I couldn't find these other threads. I want to polish the spine of my airstream and I don't want to walk up there.
Bob, bill n vinton, new to asing, 589 6760, give me a call if u can help a new aser
08-15-2016, 09:28 PM
#42
Vinton
, Louisiana
