Old 08-13-2010, 06:53 PM   #1
1968 20' Globetrotter
fair oaks , California
How do you get the side marker lights off?
When I try to unscrew them they just spin but don't come off. It doesnt look like I can pop off the lens to see if there is a screw underneath that keeps them on. Whats the secret?
Here is a picture of one of my side marker lights:
dmcinfo is offline   Reply With Quote
Old 08-13-2010, 07:18 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure how you could spin the light without removing the 2 screws under the lens that holds them on.
The lens pops off and then the screws are removed.
2004 Excursion 4x4
Old 08-13-2010, 09:20 PM   #3
I tried to pop off the lenses but I needed to flare out the aluminum case surrounding the lens a bit before I could get the lens to pop out. Should be able to reinsert the lens and then squeeze the case back to its normal looking position. Turns out that my marker lights are rived in, not screwed. Appreciate the advice.
Orange Side Marker philippes Classic Motorhomes 3 07-12-2015 04:48 PM
Side marker and clearance lighting 1960 tradewind 2vets Lights - Interior & Exterior 5 06-12-2010 01:05 PM
New Airstream LED Side Marker Lights Colonial Airstream Commercial Listings 5 02-06-2008 05:34 PM
Marker lights nyrabbit Our Community 6 06-20-2006 08:07 PM
Marker Lights ... sovereignrwe Lights - Interior & Exterior 3 08-08-2005 03:47 PM
