Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 04-28-2004, 09:37 PM   #1
RichardT
RichardT's Avatar
Profile:
Rivet How do I get the last bit of paint off?
What can I do to remove this paint stripper resistant paint from the skin? This trailer was painted by the original owner when it was new and the skin is very strait, it has been stripped to this point, now what? more pictures at http://photos.yahoo.com/richtrich also it is 21' long and by the serial number 2111 I am wondering if it is the 11th one built or the first one built, any idea? also those windows front and rear fit really well and while they shouldnt be there they appear to be factory additions, anyone know?
ID:	6263   Click image for larger version
ID:	6265   Click image for larger version
RichardT is offline   Reply With Quote
Old 04-28-2004, 10:51 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
What have you already tried?
Kleen Strip Aircraft Stripper takes off just about everything!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 04-29-2004, 12:41 AM   #3
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1953 21' Flying Cloud
Amherst , New Hampshire
You have quite a job~
richardt,
You have quite a task on hand~! But, you know this by now
What you have uncovered looks to be what was once used many years ago in the aircraft field~ Tinted yellow or green Zinc Chromate, is my guess from looking at your photos. If so, this is very good stuff! (But, not for you at this time.) This used to be used quite a bit in aircraft applications (aluminum) due to its corrosion inhibiting properties, but since it was considered hazardous, water based coatings are now used.You may find that a very aggressive application of acetone or xylene will be needed to try and remove the remaining traces.
Here's a sites that may be of some help.
For thinners, etc.
http://www.randolphproducts.com/aeronautics2.htm
You may want to also consult with a professional aircraft maintances shop for additional help.
btw, I grew up in Southern Pines, NC. Are you anywhere near?
I wish you all the best in your process.
ciao
53FC
AIR 807
53flyingcloud is offline   Reply With Quote
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 2 10-15-2008 08:54 PM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 09:18 PM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 08:03 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 06:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 09:14 PM
