Old 04-20-2009, 08:24 PM   #1
Mainstream's Avatar
Louisburg , North Carolina
How do I get streaks off an AVION
I have a real problem with streaks from possible acid wash by P.O.
on my Avion. I can not find ANYTHING that will touch that anodized finish.
It is covered with what looks like water streaks. I have tried Muriatic Acid, Rubbing compound, Mothers polish, BonAmi Etc. and NOTHING will do anything to remove even the least bit of those hideous streaks.
Has anyone had this problem and how should I deal with it short of wet sanding with super fine sandpaper?
"Shiny Aluminum Bodies will always turn a REAL man on"
Don't Let the Grass Grow under your Rig!
2004 GMC2500 HD Duramax~ 1987 Avion 30 P
Mainstream is offline   Reply With Quote
Old 04-25-2009, 10:51 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Search around Net for more info from other Avion owners. I had a Silver Streak, and was working with EaCo Chemical for some products to bring that anodized back to life. I suspect that a great deal of experimentation is in order. My main concerns were the use of a pressure washer, seal deterioration (at windows and at panel joins), and irreparable problems. Seems you might already be on the final one, so, maybe the experimentation won't be so worrisome. Hope you'll post back here -- maybe post photos -- and show us your work, and comment on same.
Good luck.
Old 04-26-2009, 05:05 AM   #3
Mainstream's Avatar
Thanks Rednax. I have ordered Alumabrite and will let you know how that comes out.
BTW I love the pictures of your Silverstreak. It must have broke your heart to sell it. She looked Gorgeous. My avion is a striking beauty inside and out also all except for those pesky water streaks on her. I even tried wet sanding with a random orbital sander and 220 paper but it never touched it. That anodized finish it extremely tough. I am sure I will get it corrected sooner or later somehow. I will try to post some pictures of the problem later.
Old 04-26-2009, 05:34 AM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Just to show.
I have this picture of respectful results from just cleaning the surface of an AVION. I don't have all the details as to what he used but, I can check around and, ask him the next time I see him..
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
How about an Avion? darkStar Vintage Kin 48 07-07-2016 06:31 AM
need help with a '71 Avion silvermoon71 Vintage Kin 4 09-29-2008 08:43 PM
Avion davidz71 Off Topic Forum 18 11-14-2005 04:10 PM
Avion Help ? aviontt Vintage Kin 1 08-09-2005 06:22 PM
