Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 08-04-2006, 12:32 PM   #1
dufferin
dufferin's Avatar
Profile:  2007 28' International CCD
on the go , Canada
Images: 11
How to clean the skin
hi you guys,
what kind of product do you use to clean up the skin of your AS.
Mine is a Overlander 1975, and the clear coat is not in bad shape, but I'd like to know if I can make it more bright,
thanks in advance,
Pdt Canadian Atlantic U. - WBCCI # 6162 - AIR #8059
http://airstream-radio.blogspot.com/
Attn : IBT
Here's what the free of speech is :
"I may not agree with your ideas but I will fight to death to let you express them"
Voltaire - (rough translation from french)
dufferin is offline   Reply With Quote
Old 08-04-2006, 12:45 PM   #2
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Use the Search...
If you use the search tab above and look for Walbernize or wax or clearcoat, you'll find a series of discussion threads... Many owners loyally use Walbernize products, which are often sold at airstream dealers. Others have tried and used different products... Feel free to follow their recommendations, or try something new and join the debate...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 08-04-2006, 01:04 PM   #3
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Originally Posted by dufferin
hi you guys,
thanks in advance,
You know, I found that just giving the trailer a really good bath and then Walbernizing it does miracles for it's "10ft" look. ( 10 feet away)
I also found that scrubbing the window frames to a bright luster and cleaning the wheels and tires really good makes a huge difference in the overall appearance. If you really want to score points, then do a major cleanup on the tongue, propane tanks and bumper area, and your trailer is sure to catch all kinds of compliments.
I have attached a few "before and after" pictures of my first trailer, a 1971 Tradewind. This might be a lot more work than you bargained for, but it really spruces up an otherwise "ugly" trailer.
ID:	24261  Click image for larger version
ID:	24263  Click image for larger version
Uwe
Old 08-04-2006, 04:03 PM   #4
dufferin
dufferin's Avatar
on the go , Canada
Images: 11
great job,
is that walbernize product?
and which one,
looks really good,
congratulation
Attn : IBT
Old 08-04-2006, 04:07 PM   #5
uwe
418
uwe's Avatar
Images: 40
No, Walbernize is a protective wax that is favored for older Airstream finishes. It goes on just like waxing a car, wax on-wax off, one panel at a time.
I just wanted to show an example of how how easy it is to make an old bucket look like something desirable. ( not meaning to say that your trailer is an old bucket - I am referring to mine)
I used primer and paint that is available at Home Depot on this one. You can also use better products, such as POR 15 etc.
Uwe
Old 08-04-2006, 04:12 PM   #6
dufferin
dufferin's Avatar
on the go , Canada
Images: 11
I was looking for POR 15 in Canada but I do have a hard time to find it,
and sometime you just don't see evidence, as I am writing, I am thinking of the fact that one of my neighbourg own a Classic Car Magazine, as soon as I am home, I will ask him...
And again it looks good,
what kind of paint remover did you use on the frame, if it's something special,
Attn : IBT
Old 08-04-2006, 04:24 PM   #7
uwe
418
uwe's Avatar
Images: 40
Try their website www.por15.com
I di dnot use an y stripper on the tongue. I cleande briefly, wirebrushed loose paint, and then sanded everything. Teh close -up shows that I did not even do a very deep sanding job, just scuffing enough to make the paint stick. My technique can easily be improved upon, is what I am saying. But it lasted really well, still looked great when I sold the trailer in 2005.
Uwe
Old 08-04-2006, 05:25 PM   #8
rebel beck
rebel beck's Avatar
Profile:  1975 31' Sovereign
Oxford , Mississippi
Images: 35
I also like the liquid glass do a search and you will find alot of post and it is safe for clear coat. It is available at Auto Zones. To me it last longer then the ubove mentioned. As you will find out we all have our little quirks we like.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 08-05-2006, 06:28 AM   #9
dufferin
dufferin's Avatar
on the go , Canada
Images: 11
I took a closer look to the Walbernize products and it seams that they're not recommanded for clearcoat finishes...
and my 75 overlander has clearcoat...
so should I use it?
Attn : IBT
Old 08-05-2006, 08:29 AM   #10
uwe
418
uwe's Avatar
Images: 40
so should I use it?
I learned that their RV Super Seal is safe to use.
However, it's not the only RV wax that works well, as others have stated.
My 1971 had clear coat, and it cleaned and protected what was left of it quite well.
Uwe
Old 08-05-2006, 12:36 PM   #11
Frank S
Frank S
Profile:  1973 27' Overlander
peoria , Illinois
Hi uwe--I really like the way you spruced up the tongue, propane tanks, and rear overhang--looks great, and very professional. I have used a less sophisticated method. Wire brush loose paint and rust. Spray with aluminum or sliver spray can paint. I usually load up on the paint when WalMart has them for $1, and carry a can for touch up, which can be done at any time.--Frank S
Frank S is offline   Reply With Quote
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 12:00 AM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 1 06-01-2002 08:08 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
Under Belly Skin Restoration... Andy R Cleaning, Stripping & Polishing 2 04-08-2002 11:46 AM
