Old 08-09-2010, 07:07 AM   #1
loislane's Avatar
2014 23' International
Saint louis , Missouri
Help with removing corrosion
Hi - this is my first post to this forum. We have a 2008 Int'l and we're already seeing corrosion. Our local dealer told us to try Corrosion X but it doesn't seem to remove it. I'm attaching photos here. Can anyone tell me how to remove this?
Thanks, Loislane
ID:	108390   Click image for larger version
loislane is offline   Reply With Quote
Old 08-09-2010, 07:25 AM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Hi neighbor! I have an 06 with the same issues. I also have a small amount on the rivets. I bought corrosionx and not much help. I bought biosheild and it seemed to turn it grey (killed it ?) but my tail lights are bad! I'm thinking of ordering new ones? I've searched on here (tons of threads) but it's more "I have it" than this is how to fix it, or I got blurry eyed reading ALL of the posts! I've waxed it keep it clean and left biosheild on the areas that have corrosion but will work on her before I store it for the winter and I hope to remove it all. I will post any success.
Are you going to Branson for the Midwest rally in October? I'm going to try and make it.
blmitch5 is offline   Reply With Quote
Old 08-09-2010, 08:31 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Corrosion X nor Boeshield will remove this corrosion. It's purpose is to protect from further corrosion in this case, and protect other exposed areas from developing it.
It looks like you also have corrosion on the lower edge of the end cap(s), and this is typical and common. The metal panels and fittings have a manufacturer-applied clear finish, ironically to keep the aluminum shiny and new looking. At the edges moisture will seep in and the process starts.
We have had good luck applying Corrosion X or Boeshield about once a month, in a small quantity (I use a Q-tip), on the exposed edges, particularly the end caps and metal fittings, and it seems to have stopped progression of the corrosion.
Do not grind off the present corrosion unless you have discovered a process to apply new finish, as it only will make it appear worse. A few have carefully used a pencil eraser to rub it off, and then applied clear automotive finish with a touch-up applicator. The Airstream Store sells one. Just do not be aggressive with it.
My approach is to treat it regularly with Corrosion X with a Q-tip, keep the trailer clean and away from a salt (corrosive) environment, and "waxed" with a modern poly finish.
It looks nice and shiny, and seems to be preserved. A greater concern is water leaks, inspect regularly, as they can and will destroy your wood subfloor without you knowing it.
Regular monthly inspection and maintenance is the key to a healthy trailer.
Doug
Old 08-09-2010, 09:06 AM   #4
_
HI LOIS and welcome to the forums...
the decay on grab handles, tail light castings, UNcoated wheels or other metal bits...
is not exactly the same issue as filiform CREEP under the alcoa clearcoat.
still slathering parts with inhibitors PRIOR to the corrosion helps.
it's often faster to REPLACE rotting parts than repair them,
but for those wanting to clean, smooth and coat the casting, handles and tail lights, RC did a very nice job
see posts # 489 and 493 below...
http://www.airforums.com/forums/f142...tml#post606944
http://www.airforums.com/forums/f142...tml#post607273
basically this is accomplished by masking OFF the skin and sanding, smoothing...
then spraying with primer/inhibitor, silver paint and a coat of wax/sealant.
the hinges and handles can't be removed easily to DO this work,
but the tail light casting can be taken OFF to redo.
cheers
2air'
Old 08-18-2010, 06:47 AM   #5
ctalley316's Avatar
2006 25' Safari SS SE
Eden , North Carolina
We have a 2006 Safari that we purchased new and have the same problems. It is strange as my husbands parents had a 1969 Airstream that they had for 30 years and never had these issues.
Cindy
ctalley316 is offline   Reply With Quote
Corrosion. Plan4Travel Buyer Guidelines 5 06-01-2010 12:57 PM
Corrosion offleash Ribs, Skins & Rivets 5 01-04-2008 08:07 PM
Corrosion Zugbug Ribs, Skins & Rivets 7 07-06-2006 05:16 PM
Need help with corrosion SAMCPA Ribs, Skins & Rivets 8 04-28-2006 09:14 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
