Old 11-13-2011, 01:20 PM   #1
DaCosta's Avatar
2007 22' International CCD
fLUSHING , New York
Help! Someone spray painted graffiti on my 2007 AS
I am so upset some one sprayed paint, graffiti on my 2007 airstream helllllllp me how do i get this offff please am so depressed. thank you
DaCosta is offline   Reply With Quote
Old 11-13-2011, 02:00 PM   #2
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Graffiti remover
There is a Graffiti remover chemical that comes in a can. I got some at Lowe's in the cleaning dept. Our school system uses it on walls etc.
Don't know what it will do to Aluminum though. Maybe use a little on a test spot in an inconspicuous place.
Hopefully, some others with more experience can give you some advice here.
Take lots of pictures. Notify your insurance company and the police dept. before you touch the aluminum. But you need to try to get it off as quickly as possible.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 11-13-2011, 02:01 PM   #3
1974 Argosy 22
1976 Argosy 28
1972 Argosy 24
Chico , California
Check with a graffiti removal company, that may be the safest. check your insurance too, they might help.
twilder is offline   Reply With Quote
Old 11-13-2011, 02:32 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
This is an Airstream ...not a brick wall. Graffiti should be handled accordingly by someone other than a guy with brick wall-box car experience. With luck, if you had a wax coating on the trailer you may be able to re-wax off the paint. ...and not your clear coat. It may even come off with an aggressive washing. Other than that go for an automotive/aircraft paint shop for ideas. Stay close to the insurance company rep.
Old 11-13-2011, 03:17 PM   #5
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
When I was working, we had to contend with graffiti all the time.White painted trailers with large lettering VERY TEMPTING. We used something like GOOF OFF I think . I know its a citrus based paint remover. Take pictures IMEDIATELY ,NOTIFY the COPS. NOTIFY your Insurance carrier. DO NOT DELAY in the removal any longer that nessesary. The longer you wait the worse it will get. I think the clear will stand up too this stuff.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 11-13-2011, 03:55 PM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
A light application of Acetone will work. If your are not familiar with it don't use it. I can take off the coating on the trailer too.
Michelle TAC MT-0
Sarah, Snowball
Old 11-13-2011, 04:12 PM   #7
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
A few years ago my truck was spray painted. Surprisingly, a mild detergent and some patience took care of it. I would just start with a sponge and soap and go for it.
I would not hesitate getting some Simple Green on it either.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 11-13-2011, 04:17 PM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
With fresh paint HOT water will often work. The water should NOT be too hot to put your hand in - about 120-125 degrees F.
Use a plain old terry wash cloth, dip in hot water and apply wiping semi-vigerously.
The bond between the paint and your clearcoat will strengthen as time passes - so try at least one spot immediately. If it works, change your wiping cloth out frequently and just keep going.
A plastic razor blade may help with the stubborn stuff too.
That is a terrible thing to happen, but it is fixable. You can get one or two panels re-clearcoated at several renovators - the ones in Helena Ohio regularly do just the top sections.
Hope you can get it off without needing to strip the clearcoat. Let us know your progress. Sympathy Karma to you.
Paula
Old 11-13-2011, 04:35 PM   #9
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The weakest solvent that sometimes gets some paint off is mineral spirits. Charcoal lighter by a different name. The paint on the later model Airstreams, like yours are precoated at the sheet aluminum maker and have a more resistant paint system. Older Airstreams with the Spray on Plasticoat are more susceptible to solvent so you need to test more and get the solvent on and off them as quickly as you can.
Old 11-13-2011, 04:50 PM   #10
DaCosta's Avatar
fLUSHING , New York
Thank you all, i tried most of the ideas you have given. This was tagged by a city rat that used a paint that isn't easy to take off. So far rubbing alcohol and been working, it takes two hours a letter. I guess i have been lucky but now i am worried. Please keep sending me more and thank you from my hard
Old 11-13-2011, 05:25 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
A friend who was a sign painter, did fancy signs and boat transoms, used a remover that would take off only one layer of paint. You might check out high end paint stores, also, automotive paint supply stores. There is lots of stuff out there that the box stores do not carry as it is not a big seller.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 11-13-2011, 06:03 PM   #12
Overland Adventurer
The Manfam's Avatar
2009 34' Panamerica
2004 34' Classic S/O
Thin Air , Rocky Mountains
Careful!
DO NOT USE ACETONE, MEK OR LAQUER THINNER! These are all way to aggresive... you will soften and dissolve the clearcoat!
Use nothing more than mineral spirits (AKA paint thinner). You can also use marine stove fuel (AKA denatured alcohol), goo gone. If you are brave you can try naptha (lighter fluid, not charcoal lighter)
If all else fails, a wet sanding grade of sandpaper can be used (4000-6000 grit) or a 3M cutting compounding gel.
The last thing you want is to soften the AS clear coat!
Don't forget about old fashioned clay as well!
Bastards!
Good luck!
FYI a 2x yearly coat of NuFinish (orange bottle wax) makes this less of a trauma!
If overland travel was easy, everyone would do it....
The Manfam is offline   Reply With Quote
Old 11-13-2011, 07:02 PM   #13
1969 27' Overlander
Kimmell , Indiana
A sign painter once told me that he uses oven cleaner to remove lettering enamel off from an automotive finish.
Hoosierdaddy is offline   Reply With Quote
Old 11-13-2011, 07:15 PM   #14
2005 30' Classic
Images: 12
What about Goof-Off?
GetOutDoors is offline   Reply With Quote
Sunburn or spray paint? Tabasco Cleaning, Stripping & Polishing 10 05-24-2012 10:01 AM
Nice 2007 airstream safari 25ft travel trailer snice 2007 airstream safari 25ft trav eBay Watch Airstreams on eBay 3 12-31-2011 02:09 PM
Nice 2007 airstream safari 25ft travel trailer snice 2007 airstream safari 25ft trav eBay Watch Airstreams on eBay 0 09-07-2011 08:50 PM
2007 Airstream Flying Cloud Windswept Airstream Registry Discussions 0 09-07-2011 06:45 AM
Hand Spray #19289 sprayer seals/gaskets missing Silver Otter Sinks, Showers & Toilets 3 03-26-2011 03:35 PM
