Old 03-18-2015, 08:26 PM   #1
1994 25' Excella
Boerne , Texas
HELP! Citrus Strip left milky spots
I applied the Citrus Strip , left it on for about 4 hours, power washed and it seemed to work pretty good. But I missed a few spots , so I re-applied and left it overnight. power washed the heck out of it. But I still have these milky spots. So then I took it to a Airstream refurbisher in Johnson City Tx. and he applied Aircraft stripper to the entire trailer. Still got the spots. He says I have to polish it to get them out.
bobglasheen is offline   Reply With Quote
Old 03-18-2015, 08:29 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Have you tried a hand wax or light compounding?
MICHAEL
Old 03-18-2015, 09:48 PM   #3
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
In a small test area, try hand buffing it out with a cloth soaked with the citrus strip. Do not add water to rinse off, just buff it off with a new clean cloth. I know with a citrus product I use at work I get the milkyness when water is added so I just let it evaporate then wash a while later.
Let me know how it works for you
thesignlady is offline   Reply With Quote
Old 03-19-2015, 08:22 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I removed my clear coat using Citrustrip, aircraft stripper, and a clean-up "wash." I got some spots that might be described as milky spots, but I don't think they were the result of any of the strippers I used. Being that my trailer was a '73, the clear coat was irregularly disintegrating all over the trailer, so I am more inclined to believe that I had spots where there was no clear coat, that had already started oxidizing (perhaps accelerated by a blob of bird crap), and when the rest of the clear coat came off, revealing fairly shiny aluminum underneath, these oxidized spots became very visible.
Eventually I will polish the entire trailer. Something you might try on these milky areas is a bit of that "Diamond Brite" aluminum toolbox polish (you can find it at the big box hardware stores and some autoparts stores). It has a little chemical oxidation remover, and a little bit of abrasive to it.
good luck!
Old 03-19-2015, 10:31 AM   #5
1976 21' Globetrotter
Anderson , California
Post pics please..!
Maybe, leaving on the citrus strip for overnight was to long? I bought some but have not tried it yet.
AirstreamPat is offline   Reply With Quote
Old 03-19-2015, 12:14 PM   #6
1964 26' Overlander
Dana Point , California
I'm preparing to stripping my '64 Overlander and considering the citrus strip. Hope to get an update when you figure out the solution.
jimj is offline   Reply With Quote
Old 03-20-2015, 05:32 PM   #7
1994 25' Excella
Boerne , Texas
citrus strip
I used Mothers cleaning wax and it worked. But if I had to do it over again I think I'd pay somebody to strip it with aircraft cleaner. That stuff is really strong and I don't want really feel like messing with it. You have to have a special chemical resistant brush to apply it or your brush disolves. Leave it to a pro
Please help- stripped and started polishing- white spots Shawnna Cleaning, Stripping & Polishing 32 05-29-2015 07:08 AM
Left turn and left brake lights not working Morgan guy Lights - Interior & Exterior 9 02-01-2015 07:08 AM
Citrus cleaner Wiremanranch Cleaning, Stripping & Polishing 2 09-24-2012 05:28 AM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
citrus based paint remover -anyone use it ? oldvws Cleaning, Stripping & Polishing 2 12-17-2002 10:45 PM
